Tire Upsize Guide
Hello TAIgers,
I am looking to change tyres on my i20 Asta [Uber cool] which rides on 185/65R14.I am planning to upgrade to 195/65R14 or 205/60R14 or 195/60 R15.
My choice for brand is
- Michellin XM2
- Bridgestone Potenza GIII
- Yokohama S drive.
Now my worry is
- Does anyone has done 205/60 R14 upgrades for i20
- Does anyone has done rim upgrade on i20. Any drawbacks seen?
I am OK with the mileage loss on upsize.
Mr.boss,
as per our discussions on the 1st page, I'm finally going for 175/70 r13 tyres on hyundai i10 stock rims tomorrow. will update how it goes.
thanks for all the assist.
Time has come to change my tyres on my Beat which has crossed 65K KMS in 4 years, 3 months with first set of tires [:D] , Goodyear 165/65 R14 came with car. Now I am planning to up size to 175/65 R14, as per manual rim size is mentioned 4.5J. Is it possible to fit 175 section tyres on 4.5J. can someone please confirm ? otherwise I will need to stick to 165 itself.
I have finalized on these brands - Michelin, Yokohama, Bridgestone - which one would be better in terms of life & rolling noise ?[confused]
Hey there,
I'm not an expert but I've used Michelin and Yokos Earth1 - both are good
In terms of Life I'd probably go for Michelin, rolling noise also isn't noticeable so I guess it has what your looking for. Life wise hands down Michelin comes 1st.
NCR
Yes, 1 size upgrade (from 165 to 175 section) is fine on stock rims. But 175/60R14 should be the correct upsize. The circumference difference in 175/65R14 is more than acceptable limit.
In 175/60R14, Goodyear and Yokohama are the available brands I think. Of these, Yokohama (A Drives I guess) would be a better choice. Check out!
NCR
Swiftian - More than 2% difference is not advisable. Negative or positive doesn't matter. Absolute values are considered, so 175/60 has lesser % difference in overall diameter than 175/65. You can try 175/65 but it will have more chances of scraping the fenders and causing other suspension problems. 175/60 is the safest bet. [:)]
Re: Fuel Efficiency of Hyundai i10 and Grand i10
I would like to know about tyre upsizing for Hyundai Grand i10 Asta. The alloy wheel is 14". OEM tyre size is 165/65 R14. What tyre size is right for upsizing? I am confused in this matter. I have city riding as well as highway riding. Your opinion in this matter will be highly appreciated.
Mr.Boss,
While going through the tire upsizing calculator I still have confusion. May be my ignorance in this matter. Please help. Hyundai grand i10 OEM stock tire size is 165/65 R 14. If I change to 185/60 R 14 the difference in error is 1.32% or something. But if it is for 175/60R14 the error difference is .75%. So my assumption is to go for 175/60 R14. Your reply is final. Since I am not a techie my ignorance in this matter may please be excused. Your reply will be authentic and will be anticipated.
Thread Starter #73
Madras
Change in circumference / error while upgrading from 165/65R14 is,
185/60R14 : +1.3%
175/60R14 : -0.7%
Hope you got the answer.
175/60R14 will reduce the ground clearance by couple of 'mm'. Though it is negligible, 185/60R14 will give a better comfort and braking when compared with stock spec and 175 section width tires.
I'm planning to change my stock tyres (grand i10) and have been offered by a dealer - 165/70 r14 yokohama earth 1. Is this a good option?
