how to get max fuel efficiency,Tips!!! & Reasons
Hi , TAIgers
This this another yet useful thread by your Prasanth Krishna ,
Enjoy.
NOTE: Thread may be longer than you think, better have a cup of coffee and relax yourself,
If you are in an hurry, please take a time later to read, because this is going to be more deeper to understand and could save you 30% of your fuel bills.
As the fuel prices are increasing more aggressively these days, our cars consume those without knowing the prices, so better you train them to get less fuel for attaining more distance
Keep in mind, every thing about max fuel efficiency is not only on saving money, its all about how greener you are in roads .
Its all about KEEPING THE MOMENTUM OF YOUR CAR,TO COVER DISTANCE
If you are a beginner go with basic things as below, else you are a pro!!
Go for pro reader section after this section.
FOR BEGINNERS
Whether you drive a tiny car or a three-ton SUV, chances are you can squeeze a bit more distance out of each gallon of fuel -- and at today's gas prices, an improvement of just one or two miles per gallon can really add up. These ten fuel saving tips have served me well over the years, and they can help you improve your car's fuel economy and take some of the sting out of high gas prices. Most of these tips will give you a very slight increase in kmpl -- but use several together and the gas mileage improvements will really add up.
1. GO Slow
One of the best ways to save gas is to simply reduce your speed. As speed increases, fuel economy decreases exponentially. If you are one of the "ten-over on the freeway" set, try driving the speed limit for a few days. You'll save a lot of fuel and your travel times won't be much longer.
2. tire pressure
Under-inflated tires are one of the most commonly ignored causes of crummy KMPL. Tires lose air due to time (about 1 psi per month) and temperature (1 psi for every 10 degree drop). Under-inflated tires have more rolling resistance, which means your engine has to work harder to keep your car moving. Buy a reliable tire gauge and check your tires at least once a month. Be sure to check them when they are cold, since driving the car warms up the tires (and the air inside them), which increases pressure and gives a falsely high reading. Use the inflation pressures shown in the owner's manual or on the data plate in the driver's door jamb.
3. Air filter
A dirty air filter restricts the flow of air into the engine, which harms performance and economy. Air filters are easy to check and change: See your owner's manual for instructions. Remove the filter and hold it up to the sun; if you can't see light coming through it, you need a new one. Consider a K&N or similar "permanent" filter which is cleaned rather than changed. They provide better airflow than throw-away paper filters and they're better for the environment.
4. Accelerate with care
Jack-rabbit starts are an obvious fuel-waster -- but that doesn't mean you should crawl away from every light. If you drive an automatic, accelerate moderately so the transmission can shift up into the higher gears. Stick-shifters should shift early to keep the revs down, but don't lug the engine; downshift if you need to accelerate. Keep an eye well down the road for potential slowdowns. If you accelerate to speed then have to brake right away, that's wasted fuel.
5. Hang with the trucks
Ever notice how, in bad traffic jams, cars seem to constantly speed up and slow down, while trucks tend to roll along at the same leisurely pace? A constant speed keeps shifting to a minimum ,important to big-rig drivers who have to wrangle with those ten-speed truck transmissions ,but it also aids economy, as it takes much more fuel to get a vehicle moving than it does to keep it moving. Rolling with the big rigs saves fuel (and aggravation).
6. Get back to nature
Consider shutting off the air conditioner, opening the windows and enjoying the breeze. It may be a tad warmer, but at lower speeds you'll save fuel. That said, at highway speeds the A/C may be more efficient than the wind resistance from open windows and sunroof. If I'm going someplace where arriving sweaty and smelly could be a problem, I bring an extra shirt and leave early so I'll have time for a quick change.
7.Use stock tyre sizes
New wheels and tires may look cool, and they can certainly improve handling. But if they are wider than the stock tires, they'll create more rolling resistance and decrease fuel economy. If you upgrade your wheels and tires, keep the old ones. I have fancy sport rims and aggressive tires on my own car, but I keep the stock wheels with a good narrower-tread performance tire in the garage. For long road trips, the stock wheels give a smoother ride and better economy.
8. Clean out your car
If you're the type who takes a leisurely attitude towards car cleanliness -- and I definitely fall into that category -- periodically go through your car and see what can be tossed out or brought into the house. It doesn't take much to acquire an extra 20 to 30 kgs. of stuff, and the more weight your car has to lug around, the more fuel it burns.
9. Downsize or hybridize
If you're shopping for a new car, it's time to re-evaluate how much car you really need. Smaller cars are inherently more fuel-efficient, and today's small cars are safer and roomier than ever. And if you've never considered a diesel, maybe it's time .
10.use assistive devices
If your car is a ob2 complaint device, you can buy a Bluetooth OBD2 connector(rs.500 to 1000 Rs.),to pair with your smart phone,these apps communicate with your cars computer and shares information like speed,rpm,fuel pressure,breaking,acceleration,engine load,etc.so you can feel free about driving,where these devices assist you to the max.use torque pro app,and many apps will suggest you to shift up or low according to speed and momentum of car, these are not costly products, but will save you lot of fuel.(a must have for all cars.
Hi , TAIgers
Enjoy.
FOR BEGINNERS
1. GO Slow
2. tire pressure
3. Air filter
