The New Yamaha R15 - Now Launched
Re: Spied - The New Yamaha R15
Though the bike seems a little taller the handle bar position is a bit low IMO and so it still should not be comfortable for tall people like us.
So i think the new R15 must have hit the dealerships already! Its only a matter of time till they completely sell off the remaining old stock!
Yes! And the launch is happening on 5th September at New Delhi. This is what a Facebook Fan of TAI sent on our wall.
Yamaha R15 v2 launched!! [thumbsup]
- Yamaha R15 Version 2.0 launched at the price of Rs. 1.07 lakh ex-showroom Delhi.
- Colours – Racing Blue, Midnight Black and Sunset Red.
- 90 mm front tyre, 130mm rear tyre
- 220mm rear disc
- New 5 spoke alloy wheel (looks like a 10 spoke)
- Wider tyres both at the front and rear.
- First Aluminium Swingarm in India on the R15
- 130 / 70 – R17 rear tyre
- Sharper tail
- LED taillamp
- Split seat
- No changes made to the instrument cluster
- New exhaust muffler
- 5 kg lighter than the earlier version
Products | India Yamaha Motor Pvt. Ltd.
Engine type Liquid-cooled, 4-stroke, SOHC, 4-valve
Cylinder arrangement Single cylinder
Displacement 149 .8cc
Bore & Stroke 57×58.7mm
Compression ratio 10.4:1
Maximum power 17PS / 8,500rpm
Maximum torque 15 N.m / 7,500rpm
Starting system Electric Start
Lubrication wet sump
Engine oil capacity 1.0 liters
Fuel tank capacity 12 liters
Fuel supply system Electronic fuel injection
Ignition system T.C.I
Primary / Secondary reduction ratio 3.042 / 3.000
Clutch type Constant-mesh wet multi-plate
Transmission type Return type 6-speed
Gear ratios 1st=2.833, 2nd=1.875, 3rd:=1.364,
4th=1.143, 5th=0.957, 6th=0.84
Chassis
Frame type Deltabox Frame
Caster / Trail 26° / 100mm
Tire size (Front / Rear) 80/90-17 / 100/80-17
Brake type (Front / Rear) Hydraulic, single disc (Front / Rear)
Suspension type (Front / Rear) Telescopic / Linked type Monocross
Headlight 12V35W / 35W+35W
dimensions
Overall length x width x height 1,995mm x 670mm x 1,070mm
Seat height 790mm
Wheelbase 1,290mm
Minimum ground clearance 160mm
Dry weight / Curb weight 120kg / 131kg
AMG
N/A
If the saree guard is mandatory, then so should be the rear grab handles.
It makes absolutely no sense in not having a grab rail.
It to me seems amusing that the govt is concerned about sarees not getting stuck in the wheel, but doesnt care if the pillion falls off.
Also, how much weight would a grab rail add?
At most 0.5 KG.
Also when the current bike is 5 kg heavier, why skip on an important feature?
Also the fact that Yamaha is known to give the best quality products.
One cant help but think whether it would not have been appropriate to include an optional ABS?
Re: Spied - The New Yamaha R15 - Now Launched
If the R15 is widely accepted in the export market, then that will be a big achievement, and a proud moment for all the existing R15 owners.
However, keeping in mind the heated up competition with the inclusion of CBR150R, Duke 200, and 200NS,the export might very well be a PR stunt as well.
Export is Necessary for Yamaha India, as their production capacity to sales ratio does not match.
