Hey Buddy, congrats on the GP! Looks really good in red. I like the steering mounted audio controls.
Yes. Me also fond of this functionality and Blue and Me
The seat height adjustment, does it vary the height of the seat as a whole or is it a see saw kind of arrangement?
The Height seat adjustment varies height of seat as whole.
Regarding the FE, it depends a lot on your driving style too. You mentioned that you are new to driving, or so I assumed. If you have been driving petrol cars before, you could find it to cause problems for diesel, well not completely.
I am new to cars of any type. I never drove any petrol car also. it like Diesel is my 1st car.
Diesel cars have so much more torque that you should learn to use that to your advantage.
Try to shift up and shift down soon. So that means not staying in a lower gear for too long and waiting it to reach 3000 RPM. Change the gears around 1500 RPM. Diesel car can give a wonderful push at 2nd and 3rd gears at lower speeds and you don't even have to use throttle. This can be used in slow moving traffic where you can control the car with just clutch and break.
My Lot of friends who have M800 or Indica feel like its Rocket
Try this, may be on a less used road but having humps. Get to second gear before you reach the humps and control the car with the clutch and breaks. You should be able to feel the pull at that point. The car will cross the humps without any fuss and by the time you cross it, you will also have a good momentum which you can carry on with just a little throttle. You cannot do this with a petrol car since its torque works differently.
I do the above even with AC on and it works like a charm.
In Punto i do not feel power loss due to AC.
Most importantly, go through the manual. They usually provide tips on how to get the best out of your car. For a fact, we know that Punto gives around 16-17, so that should be a backing. You can definitely get around that if you can adjust your driving a little bit.
Hum. I am getting used to it really fast.
And yes, do not use the Turbo unless it is necessary. A diesel can can pickup weil without the use of turbo. Unless a car has turbo lag, which I don't think GP has, you should be fine.
