Completed one year today with my Tigor xza. :)
Things which can be improved-
- Jerkiness in 1st gear on A pedal press-release. Especially observed in stop-go situations when you need to accelerate over creep speed, while still being in 1st gear. Not sure but may be increased with sa04 ecu update.
- AMT downshifts quickly to 1st. Better if it can hold longer on to 2nd gear for a smoother drive. This is more prominent when passing over a speed breaker.
- Some niggles and fit-finish issues (rear door misalignment, fuel lid opener not opening properly, bonnet holder socket broken in just a week after purchase. But the thankfully taken care by SC well)
- Typical AMT Lag in shifting from 1st to 2nd gear.
- Sudden surge in M mode. Car surges ahead aggressively, with a light tap on A pedal in manual mode, making it difficult to use in heavy traffic.
Very Rightly Observed, To Add to Your List i would like to make the following observation as well:
1. When trying to coast, the AMT decelerates faster than a regular Manual resulting in quicker down shifts.
2. To derive better performance and less jerks i have adopted myself to driving AMT,(When the car up shifts at about 2000-2200 RPM i take my foot off the pedal for whole 1-2 seconds and then step on A pedal) Its difficult in stop go traffic but reduces jerkiness a lot
3. Mine is a Tiago AMT but considering the same engine i believe the behaviour would be same, To Get better fuel efficiency once i step on the pedal with lightest of foot the car picks up pace really well yet giving good FE.
4. I wish the car could upshift at about 1700-1800 RPM as i have hardly driven the car in 5th gear in A Mode, yes in Manual you can upshift early but as soon as the speed drops below 50 it downshifts to 4th gear so failed attempt at this also.(this would further improve FE i guess)
I also have a Question to ask not you personally but every AMT Owner
When Driving at constant speed in any gear my Insta FE bar hardly goes beyond half way mark with AC only in 5th gear its up by 2 points of the half way mark. is it the same with everyone?
On the Contrary i have driven ignis AMT which drives past 20-25 mark on insta FE at constant speed. I expected Tiago to be a little more Fuel Efficient than this.
When Average speeds 20-30 kmph with AC 12-13 kmpl
When average speeds 30-40 kmph with AC 13.5-15.5 kmpl
When average speeds 50-60 kmph with AC 16-17 kmpl
Not tested Highway yet
