Well, Most likely it will be H for Harrier
Have posted in page 8 or 7. Do check bro.
1.Three Tatas in one Garage. This will be Phenomenal!
2. Not able to locate pic.
Mr.BHVM , a small correction and addition
Nitrogen in Service centres and Fuel pumps are scam.
But one in tyre shops (Special mention to MRF outlets) are generally best.
Personal advantage i felt with N2 is -
My ride had a puncture in a nearby town , from that to my town , about 35km , the car had run , the pressure drop in tyre was only 7PSI. The car was run to tyre outlet only after I noticed .(Rear tyre , so thereby can't be felt by driving).
If it had been case with normal air , surely , the ride would be in middle of road.
Case 2 - Sidewall hit , The hit was noticed only after 2km post hit , and the air leak was very slow.
Case 3 - Generally , i check up monthly once , and pressure drop is 1-2PSI alone.Tyre remains in optimum temperature with N2.
Why i told fuel pump and dealership scam is - They tend to fill normal air itself , and bill you N2. Ensure always N2 machine is a different unit , it consist of N2 filter membrane and you can ensure it , either the machine will have a rotatory knob(Just like fan regulator)- Which can switch to normal air /N2 as per the customer's choice.
Hello Mr.VISHNUCARCRAZY,
Let me offer you a complete Correction and Major Debunking!
1. This is a Trait of Newer (15 Years or younger) Tubeless Tyres and alloys. Not N2. New Tubeless tyres don't go POP like Tubed cousins do.
Once my XUV ran 2 weeks on a Puncture. Hardly any air escaped even to trigger the TPMS. Only after coming home and letting it sit for 3 days at one place, The tyre deflated. Opon opening the tyre found 2 huge nails (Broken Nails) Inside the tyre.
In last month Suffered a huge puncture in Safari. Drove 45KMS home. Only after coming home, the tyre went flat. Upon inspection, Glass had made huge cuts in the tyre. Had to replace the tyre.
@Mayankdixit, There is your Proof that Safari users cannot figure out Punctures in Safari.
Case 2- Got 2 sidewall hits on Concrete kerbs(Pretty Sharp) when reversing in Tight spaces. Air leaks? None.
Unfortunately, Only Kerbs broke. (Safari toh Safari hai bhai!)
Case 3- I Own Tyre Inflators since Long now.
http://www.theautomotiveindia.com/f...ytvs-tdi-22-vacuum-cleaner-tyre-inflator.html
Holding tyre air Pressure is a function of High Quality Tyres, Alloys (Better Bead seals) And good quality Valves.
XUV- ZERO loss over 3 months
i10 (Parked/ Hibernated)- ZERO loss over 2 months
Activa- about 2 PSI a month
Safari- 1 or 2 PSI a month in Some tyres (Probably faulty Valves or Bead issue), Zero loss in some.
So buddy, Its not N2.
Case 4- Temps can be Monitored in XUV TPMS. No issues over here. I usually do 1000 KM In single day (15~16 Hours). No Overheating even at x40 to x50kmph cruising
Basically, to those who still think n2 something special, Take a look at chart below.
Air in earth is already 78% N2. You do NOT Vacuum the tyres when filling N2 (Such heavy vacuum will destroy tyres though).
So basically there is atleast 20% normal air (By volume) inside.
https://en.wikipedia.org/wiki/Atmosphere_of_Earth
You do the math now buddy.
Which methods are you talking about ? Do tell. Even I feel gearlock is a good option.
Engine Immobilizer, Alarms, Knock and glass break sensors (In some high end cars), Computerized keys.
@Mr.Allhyundaicars,
Explain the function of Gear lock , and then i will try to explain my view. (Don't mistake my tone , seriously , I don't know what gear lock does)
Gear lock is Crude, Mechanical and outdated option by employing a lock so that the thief is not able to shift or Engage Gears. Assuming you Park in neutral (Which is a bad Idea anyways), He won't be able to steal your car.
Steering and Pedal locks also work in the same way. Haven't seen all these 3 in a LONG time now.
