Tata Sierra: Technical Queries & Solutions
Thread Starter #16
Bhubaneswar
Re: Tata Sierra - Technical Queries and Solutions
ilango[speed thirst];91099 said:
manifold of ac , that hold the ac is bend .
so the whole ac compressor is out of alignment.
so the belt don't run in straight line.
points are perfect. how come that manifold got damaged?
I don't have any idea as i have told it's a second hand car i have purchased.
Could u tell me is there any solution now.
Thanks
Thread Starter #19
Bhubaneswar
Can i get a new Manifold from somewhere.
I am going for complete engine overhaul as it has back compression as per the mechanic suggestion.. Could you just give me a approximate budget for that. And what i should look for as i am totally new to this engine work.
As well i want to complete check up of my Sierra. Could u also let me know what other areas i should take care of and if possible an approximate budget for that.
Thanks in Advance
Thanks in Advance
An Full engine overhaul including head works etc must cost roughly 25k.
may shot more due to other small expence. just be reqady with a max of 30k.
among this , about 10k will the labour charges.
For engine work ,
one need , need lining(Bore) , new piston , piston rings
In head new valves , and other parts.
Connect rod bearing etc , may too have worn out and may need replacement.
If the clutch is more than 70% used , just get new clutch/cover assy and release bearing.
Thread Starter #21
Bhubaneswar
For engine work ,
You mean around 40K.
What about the cost related to clutch if in case i need to change this.
Thread Starter #22
Bhubaneswar
Hi Folks,
Could you guys suggest a Good color for the sierra. As my sierra is going on complete remake. I mean complete engine work and after that paint.
Thanks in advance
Clutch must cost around 4k to 5k , no idea . just my guess compared to sumo old type.
no idea what brand etc.
black/ grey/ maroon / dark blue will be nice for the sierra.
saw a pearl white sierra some days before with green tints . looked nice!
Thread Starter #24
Bhubaneswar
Hi Ilango,
Thanks for your suggestion. Could u give me the color code for dark blue. I am thinking i should go with that. What about your car...
Thanks in Advance.
Hi Ilango,
Thanks in Advance.
Each brand has its own colour code.
just go to any paint shop and select colours according to the car manufacturer brands.
say , Go to a dupond shop and ask for the colour cataloge of the audi /benz/lambo etc.
drool over and select[evil]
danis11
Perth
Will a 01 Sierra 4x4 suspension fit a 99 Sydney?
Hello,
My buddy has a 4x4 Sierra with the stock lift and I have a 99 2 wheel drive Sydney. Will his stock lift fit mine when he gets a new lift kit? Please give your valuable suggestions. Thanks in advance
Re: Will a 01 Sierra 4x4 suspension fit a 99 Sydney?
Hello,
To be true , i understand that your friend has 4x4 sierra .
what is stock lift?
and what car is sydney? i have absolute no idea!
Jaipur
Re: The Tata Sierra Restoration Project
Please guide me this is my first time here and i dont know much about automobiles.
I bought a tata sierra '95 from first owner last year. I am in love with this truck. but as with everyone there are some changes or modifications I wish to know about and the possibility/feasibility.
I always feel it is slightly bend towards the back and I wish to raise its rear height for many reasons (the roll). not sure if it can be done on coil springs and I dont want to change them to leaf or any other. I had original shockers installed few months ago.
the air conditioner is disappointing. I did get a custom blower switch installed which increases air flow but not cooling. and in any condition the car never crosses 50% temp gauge but with ac on it shoots upto the red mark. though all mechanics have confirmed me here that its alright with tata sierra to get heated up with ac on. can i increase cooling and reduce the temp in any way? change to aluminium radiator or change ac unit? how successful would rear cooling wall unit would be?
the front dashboard also releases lot of heat when driving for long or on very sunny day.
lastly can somebody pls help me find its rear bumper corners & ply for doors. everything else is in great shape.
many thanks in advance.
Congrats for the car .
Could you post pictures .
From your query , i think you need to change the coil spring.
Get sierra coils. seller may try to sell safari coil spring which is exact fit , but a inch or more extra in height , which male the front dip
Clean up the radiator. changing to aluminum radiator is last most option and not need in most case.
Sierra red mark is less than 100 degree for sure.
where as modern day cars , almost 60% scale is 95 degree.
Check up my thread for alternate way . I have added a electric fan.
For ac , Sierra from 94 has subros unit , prior to that it had denso unit .
subros unit runs good for 20 years kind of if ac gas is maintained well.
This unit with superking blower and cooling coil is best .
Superking /unicla as called is 12k for original and 8k duplicate. beware.
Go for rear cooling wall if you are not satisfied with front , i bet you wont !
Jaipur
thank you so much for your guidance. I will try to post pics soon.
new coil springs sound good and if they give an increase to rear height it will be brilliant. i will look for safari coils.
superking unicla. will see if its available in jaipur my city.
what about rear bumper corners. do you know anywhere one can find them. are they available in your city.
