Some New Gadgets Found
JBL REFLECT Eternal self-charging Headphones deliver unlimited playtime outdoors
The JBL Reflect Eternal brings a whole new level of innovation to the hearable industry with the technology at play. With the JBL REFLECT Eternal, the more time spent outside each day, the more hours of playtime you get between charges. The headset packs a 700mAh battery which ordinarily should deliver up to 24 hours of playback on a single charge. However, the solar charging feature ensures the headphones can be used for an unlimited number of hours when the headphone is used outdoors. According to JBL, spending 1.5 jours outdoors will extend the usage time to 68 hours while 2 hours outside daily delivers 168 hours. Finally, 2.5 hours of outdoor time translates to unlimited playtime daily.
Read:
OPPO Enco Free wireless earbuds and 5G CPE T1 unveiled in Malaysia
OPPO says the Enco Free uses AI uplink noise cancellation. It also has wear detection, so it pauses and resumes playback when you take it out or put it back in your ear.
The Enco Free has a 5-hour battery life and goes up to 25 hours with the charging case. The case charges via USB Type-C only unlike the new Realme Buds Air which adds support for wireless charging. It takes 90 minutes to charge the earbuds and almost 2 hours to charge the case.
OPPO will sell the Enco Free for 499 Malaysian Ringgit (~$120) when it is announced in January 2020. Also, registration is already live in China ahead of its launch next week.
Read:
Xiaomi crowdfunds QBORN 360° Rotating Car Seat for toddlers aged 0-12 years old
The seat is made up of a double-layer injection-molded shell, plus high-strength, impact-resistant high-end energy-absorbing cushioning material EPP, and an outer high-density sponge U-shaped pillow. Together, these form a four-layer defense system, dispersing pressure and providing comfort and support for your baby’s head and neck.
It also supports 360° interference-free one-button rotation. By pressing the front button, it can rotate freely in any direction. It’s more convenient and flexible in use, making it simpler to interact with the child in the seat. Overall, it’s certainly an interesting idea for a product, and the execution is quite impressive. For now, it’s only available via Xiaomi Youpin, so you’ll have to import one if you want to get it.
Read:
Anker Soundcore launches Icon Bluetooth Speaker in India for Rs 4,999
The speaker is designed compact and portable. An oversized Elliptical driver works with bass up technology to produce mind-blowing Audio power from Icon.
The speaker is IP67 Water Resistant, thanks to its cleverly designed casing, Icon even floats. Being Shockproof and Dustproof, Icon rounds off comprehensive protection with super tough proofing.
The product will offer 12 hours of iconic sound from a single charge. You can connect two Icons via a single phone or tablet for suped-up sound and cranked-up colour. Its removable straps will allow you to link 2 Icons together in any way.
Read:
Portable water heater from Xiaomi crowdfunds
Compared with the compression kettles commonly available on the market, this Imperial Palace hot water machine is much more convenient to use. In terms of heating time, this instant hot water machine only needs 3 seconds to heat water to 100 ° C. Tea, noodles, etc. basically do not need to wait. Its three-stage intelligent water temperature adjustment uses a microcrystalline touch panel design, which can provide hot water at 45 ° C, 75 ° C, and 100 ° C according to different needs. It also has an automatic cleaning feature which can drain old water and clean it with one click.
The device comes with a retractable spout making it convenient to carry around. This is perhaps, the biggest feature onboard the device. The plastic body is made of ABS material with a matte finish. The weight of the water heater is said to be about the same as that of a 500ml water bottle but with a wider body. As such, it does not occupy much space in the bag.
Read:
Xiaomi releases the very simple Xiaomi Wireless Keyboard and Mouse Set for 99 yuan ($14)
The keyboard uses a 104 full-size key layout, including full sets of function keys, keypads, and arrow keys. The keyboard is equipped with Fn composite keys, and the combination keys of Fn + F1- ~ F12 support common shortcut key functions such as volume, media, mute, and song cut. There are four indicator lights in the upper right corner of the keyboard for caps lock, number lock and the power indicator.
The mouse also adopts the simple lightweight design, at only 60 grams. It’s a regular sized mouse in terms of size, with a comfortable grip and an ambidextrous design. The mouse is equipped with the a 1000DPI optical sensor, nothing too crazy. It is powered by a AAA battery, and the receiver is stored on the bottom of the mouse.
Read:
Sound One launches V10 Bluetooth wireless headphone for Rs 1390
The Sound One V10 Bluetooth wireless headphone comes with MIC offering Bluetooth v5.0 technology that assures strong and stable connectivity up to 10-meter radius clear distance from the connected device and the built-in MIC ensures convenient call management.
Sound One V10 headphones portable & foldable design gives you long hours of listening comfort. The company in a press release claims that it has superior cushioning comfort so that one can spend a whole day listening to music.
Read:
Ubon PB-X12 Power King portable power bank launched in India
Ubon, a gadget accessory brand, has today announced the launch of its latest PB-Z12 Power King portable power bank in India. The power bank comes with a price tag of Rs 2,999.
The latest power bank comes with 3-in-1 built-in cable support. The company claims that it comes with micro USB cable, a Type-C cable and lighting port to charge both iPhone and Android smartphones. The power bank comes with 10,000mAh capacity. The company claims that it can charge an iPhone 2.4 times and Android smartphones up to 2.2 times. It comes with rapid charge feature and it is loaded with IC protection that helps to avoid over-charging, over-discharging or short circuit.
It comes with a max output of 2A. It also comes with an LED indicator that shows the amount of power left in the power bank. The brand says that the palm-sized power bank is quite comfortable to hold and easy to carry around.
Read:
Xiaomi crowdfunds the MIJIA Instant Water Dispenser C1 for 199 yuan ($28)
Unlike the long waiting process of traditional water dispensers, MIJIA Instant Water Dispenser C1 has a high power of 2200W and supports 3 seconds of rapid heating. This will make it easy to get hot drinking water promptly when needed. The dispenser comes with a 2.5L large-capacity water tank which when filled with water once can meet the daily drinking needs of 2-3 people without any need to repeatedly add water.
Read:
Xiaomi Youpin launches the Baseus 3-port 60W fast charger
As the name indicates, the Baseus 3-port 60W fast charger features three output ports, two USB-A ports and a USB-C port. The charger can be used to charge laptops and mobile phones at the same time. Only the USB-C interface has an output of 60W and can be used to charge a MacBook Air (13) in just 90 minutes. The USB-A ports both come with 45W output each.
In order for the fast charger to be compatible with different devices, it comes with support for several charging protocols. The supported protocols include Apple’s PD3.0, QC4.0, QC3.0, FCP, AFC, MTK and other popular fast charge protocols in the market. The charger also comes with smart voltage detection. What this means is that if the three ports are being used at the same time, the device accurately detects the voltage and current required by the device and matches the output to reduce current loss.
Read:
Claw launches G11 dual driver gaming earphones for Rs 1490
Claw G11 earphone features a dual driver system with dual 6mm dynamic drivers on each side producing powerful bass and crisp audio so you can hear footsteps, gunshots and other important sounds clearly knowing exactly where your enemy is located at all times.
The dual microphone setup allows you to use the adjustable boom mic during gaming sessions or simply detach it and use the secondary in-line mic located on the remote for regular use. The detachable boom mic is 360 degree adjustable to pick up your voice clearly delivering accurate and smooth communication.
Read:
Xiaomi’s MIIW Wireless Mechanical Keyboard and mouse launched
The MIIW Elite keyboard uses an 85-key design with scissor keys. The keycap is round, the corners are rounded, the thickness is 7.8 mm, and the frameless design is very compact. The keyboard supports dual-mode connection, that is it can be connected via Bluetooth and also via a dedicated USB wireless receiver. Also, the keyboard has support for Windows and MacOS.
In addition, there is a voice prompt key between the “Alt” and “Ctrl” keys, to the right of the space bar. The key activates the HKUST Xunfei Voice Pack, which can not only input text by long-pressing the voice key but also double-clicking activates a series of smart operations on the PC such as querying weather and opening tables.
Read:
Oppo Enco Free true wireless earphones released for 699 Yuan ($100)
Earlier this month, Oppo had announced on social media that it would be releasing its first truly wireless earbuds. Now, the Oppo Enco Free has finally been unveiled alongside the Oppo Reno 3 series of smartphones in China.
Oppo Enco Free weighs in at about 4.6 grams and holds the title of being the first true wireless earphones that utilize ultra-dynamic speakers. These speakers are equipped with dual magnetic circuit design and an FPC arm balance system that allows for a superior sound quality output. Notably, the earbuds can be used up to 25 hours in total if used alongside its charging case.
The wireless earbuds are also equipped with “Bluetooth low-latency dual-pass” technology. In other words, both individual earbuds connect to a smartphone via Bluetooth simultaneously. According to official notes, this enables the wearables to achieve better audio-visual synchronization effect and reduce the latency by 76 percent during gaming in comparison to traditional Bluetooth earphones.
Read:
Fingers Beaute wireless headset launched in India
The latest headset is quite lightweight with just 150 grams. The headset comes with a plush leatherette on the ear-cups, which the brand claims provide comfort. The device is loaded with a 200mAh battery that gives 6 hours of playback time with 1.5 hours of charging.
The headset can be connected to the smartphone using Bluetooth or AUX mode. The wireless headset comes with Voice Prompts feature that enables the user to control call and volume functions by voice command. It also comes equipped with a MicroSD slot and FM Radio functionality as well. The wireless headset is equipped with a high-quality 40 mm driver unit that provides deep bass.
Read:
