Tachometer for enfield bullet
Quick query if you don't mind. I went hunting for a tachometer for my bullet (UCE Electra) and none of the automobile shop folks were knowledgeable or even had a separate tacho. A mechanic I know told me that he can fit a tacho if I manage to procure one. I am certain that I will be able to figure out the wiring if I could figure out what tacho to get. ( I have given up the idea of procuring a digital console like Koso or Acewell because of their sheer cost 10K+). Any idea what tacho I should be buying? For now, I plan to fit it in the handlebar.
If I manage to fit a tacho and gain some confidence, I plan to get the modifications done for a fuel sender .
Santosh, It has always been a regret that RE 350 does not have a tachometer unlike the thunderbird. And fitting a tacho is more of understanding what it needs. You can go for a tacho used in any other motorcycle like a Pulsar (old models) / Thunderbird / Fiero, etc. You get the tacho with a case for a Thunderbird & Fiero. For Thunderbird fuel guage is a bonus.
If you don't find those, but you can manage to procure a car tachometer for 4/6/8 cylinders still it is possible without any major modifications.
1) Option 1 - Connecting a motorcycle tacho to a bullet (
FOR TCI IGNITION ONLY).
These tachometers need 1 pulse per revolution of crankshaft for showing the right reading. Refer to the first figure (Tacho I/p from TCI). A multimeter comes very handy now (if you don't have access to the wiring diagram). One of the wires carries +12V as soon as you key on. You don't need that, or use it to power the tacho with +12V. The other wire goes to kill switch and also to the TCI. This is the signaling port for a single cylinder tahco. Splice this wire a little, tap an extra wire and connect it to the signaling point in the new tacho.
2) Option 2 - A petrol car tacho for bullet.
These tachometers need 2 or 3 or 4 pulses per crank revolution for 4 / 6 / 8 cylinder options. Here you need a little of soldering expertise. Refer to Figure 2. Prepare a single phase bridge rectifier across any of the 2 yellow wires from the stator. Do not add a capacitor after the bridge. The output pulses will have the same frequency as the number of magnetic poles in your maget rotor.
For example you magnet for 4 pole pieces (2 North & 2 South), The output from the diode bridge will have 4 pulses per crank revolution. So set the tachometer for the 8 cylidner option.
What if your generator has 6 poles? The bridge rectified output will have 6 pulses per revolution which corresponds to a 12 cylinder option, which you dont normally find in a low cost car tacho. So, just follow what you see in figure 3 and set the tacho in 3 cylinder mode.
The above explanation is common for any 2 wheeler. You don't need the bridge rectifier if there is already an AC output from your alternator like in a Pulsar UG3 & below. Set the tacho to as many pole-pairs (NOT POLES) as you see in your Magnet.
