Product name : DC Basics White Clay Bar
Price : 1200 INR
Weight : 200g
Grid : Fine to Medium
Seller : Detailed Clean India [ link : https://www.detailedclean.in/detailing-clay/dc-basics-white-clay-bar-fine-medium-346]
Shipping : DTDC [free shipping with tracking for orders above 1000 INR]
Time to deliver : 4 days [To Mysore]
Initial Impressions :
Used this product two times till now. Got to say it removes roughness from paint surface and brings back smooth finish. I also clay bar my windshield just incase to remove any embedded contaminants.
1. Provided with storage box.
2. Medium grid absorbs dust inside and prevents from causing scratches.
Dislikes :
1. Wish price was including clay lubricant too.
2. Too much pressure on clay bar may mar you paint.
3. Since it's a medium grid, it is slightly harder to get it into required shape.
Value for money : 7/10
Overall Satisfaction : 8/10
How to clay bar your car ?
Even before thinking about starting make sure you have a recommended clay lubricant with you. I used 3M car wash mixed with water as a lubricant. You can use water too if you want to.
Step 1 :
Wash your car thoroughly and make sure there is no dirt or any other contaminants on it. It is advisable to wash with a wax stripping car shampoo.
Step 2 :
Cut clay bar into a piece of suitable size. Make sure you hand is lubricated with the clay lubricant which you choose. Then flatten it into a rectangle/circle. Now lubricate the surface of clay bar and surface of you car.
Step 3 :
On the lubricated surface move the clay with medium pressure in a straight direction. If you feel some resistance, lubricate that spot and repeat to rub it using clay until there is no resistance.
Step 4 :
Inspect your clay bar. If it has some contaminants in to, please fold it so that those contaminants get embedded inside the clay and not on the surface of clay which will come in contact with car
Step 5 :
After claying entire surface, wash it with water so that it removes any disturbed contaminants on the surface. Then wipe it off using microfiber towel.
After clay baring you entire car, it will have a smooth surface. Now next step is polishing or waxing depending on condition.
Golden rule of clay baring : You drop it, you throw it.
Because clay bar attracts dust and sand into it so you don't have to risk scratching your paint.
Mine fell on the ground,
Price : 1200 INR
Weight : 200g
Dislikes :
Step 1 :
Step 2 :
Step 3 :
Step 4 :
Step 5 :
