Hello Interceptor!
Normally both keys should have Remote locking buttons in it.
Because once you lock your car in Remote & suppose if you try to open the car with normal key, it will try to trigger an alarm.
So, i doubt Ford wouldn't have done this!
Yes. Almost all car manufacturers are keen on this now a days.
Doesn't matter much! Life of Tyres can be decided only when it starts straching the corners & not before that!
Normally Ford Doors will be hard & gives a very masculine sound when yuou close the doors. Most of the people love it here :)
It shouldn't be a problem, If you think so, you can get that done (before delivery) in your service centre immediately.
Dont stop registration for any of the above points, because everything seems to be quite common.
Go Fida![Cheers [cheers] [cheers]](https://www.theautomotiveindia.com/forums/images/smilies/Cheers.gif)
1. The remote lock is integrated into the key and only one key with remote is available, the duplicate key does not have the remote and it just a plain one. Any idea if this is correct and someone throw some light after checking with your friends if possible.
2. Will there be a Aux out in Ford Fiesta's stock headunit?
3. Tyres are manufactured in Week 34 of 2009 so good to go there as well.
4. Front Left door handle seems to be somewhat tight to open. Is this normal?
Go Fida
