Remove the instrument cluster, then remove the speedo glass, then need to remove 2 screws located next to the speedo needle, finally pull speedo needle and then the plate out, you are done..
Quality of plastic is good.Nuts,screws,clips and everything needed for fixing is included in the box,along with a instruction manual on how to fix it..
