I have driven it only for about 15 KM myself. Spent a good amount of time going through the user manual and to get adjusted to the controls. Initial feedback so far
Gear Shift: Excellent. It slots neatly without any fuss whatsoever
Steering Control: Excellent straight Line driving. Leave the Steering and the vehicle goes in a straight line
Brake: Has a good bite. Thankfully, so far did not have the necessity to test ABS so far.
Clutch: Felt a bit hard. May be will get used to it.
DIS: Readable from the drivers angle. Fonts could have been improved
Music System: Gives a decent sound. May disappoint an Audiophile. Equalizer adjustments are decent enough to produce rich sound for an average listener. Sync up with USB device is good. Not used the remote yet.
Head Lights: Powerful and usable for the short drives that I had undertaken so far. Need to check over Highways which I will do it
Shock Absorbers: Had gone over a couple of bad pot holes and it absorbed it pretty well
AC: Very effective. Could feel the chillness in the back seat within 2 min of switching on the AC at 2nd Speed. Planning to take to Chennai in May wherein the real test of AC may happen
Rear seat space: Amazing. Even with the front seat fully pushed back, I was able to sit with about 2 fist length gap between my knee and the front seat. I am 5'9" tall
Front Lamp Adjustment: Has three levels of adjustments, which gives an ample level of throw in the front
E-ORVM: Works well and able to adjust pretty cleanly. Able to see one lane of traffic on either sides clearly without leaning to the right or left
Driver Side Power Window: Need to get adjusted as it is Single Shot. Single press and it rolls down all the way (as intended though), if my intention was to bring it down slightly.
Pickup: Good torque and car lunges forward with a tap on the accelerator
Noise Insulation inside the cabin: Amazing. In fact, a couple of times, I cranked the engine thinking it is off. Even when parked in my basement, engine noise is relatively mild.
Small Niggles (hope this stays at this count):
Panel gap in the Steering Wheel Column. Visible in all the cars seen so far
Boot Lamp stopped working and started working automatically
Window Lock on drivers seat stopped working and started working automatically
Hope I will not have any more such surprises
Overall, it has been a pleasurable experience so far
![Thumbs Up [thumbsup] [thumbsup]](https://www.theautomotiveindia.com/forums/images/smilies/Thumbs%20Up.png)
Planning to go on a long trip after the first service only. Will keep posting updates to this thread.
