Sonakshi; said:
At the side of the road there were parked cars (at a 45 degree angle to the road). I checked for traffic and found it clear and turned in the lane. However as soon as I turned in, there was a car reversing backwards from the parking into the lane right in front of my car. I hit the back corner of the car and the car got pushed forward into another parked car.
I was completely in the lane before impact and had entered the lane maybe 5 seconds before the collision.
Hi Sonakshi,
I think, this time also you failed to brake in time or you were in much higher speed.
Kindly see the words I made bold in the above quote.
The average response time of a driver is
.75 secs, and it can be
1.25secs in panic unexpected situation.
If your brakes and tires are in good shape, then a
80 to 0 kmph braking can be done just with in
3secs.
Since its a 45 degree parking, most probably you could see the car's reverse light before the car starts moving backward(Anyways its ok, since you already found the car moving backward soon after you changed the lane)
If you were in the legal speed limit, then 3secs is quite enough to brake your car to stationary and 2 secs is far enough for the response time. So getting a 5 secs before collision was really a good chance for you to avoid the collision.
When moving through the lane closer to the parking area, we should be more conscious and should reduce our speed more than that we usually cruise through other lanes. We should always expect kids running infront of the lane closer to the parking area. We should also expect the fellows to open the doors of their car in the case of driving through the lane closer to the parallel parking area.
Now About whose fault it is.
Consider you are the reversing guy
![Roll Eyes [roll] [roll]](https://www.theautomotiveindia.com/forums/images/smilies/Roll.gif)
. Do you think you can see the traffic in the lane when you are in the driver seat? It will be quite difficult to see isn't? So what all you can do is slowly reverse the car until you hear any horn or you see any vehicle.
IF you have blown the horn or reduced your speed soon after you saw him reversing his car then this collision can be avoided or atleast its impact can be reduced. Am I right?
Even though you are in the lane completely, he started moving forward after reversing from the parking space so its your fault for not braking at the right time and giving way for the vehicle infront of you.
Regards.,
Kiran.
