Mercedes-AMG C63 S E-Performance Launched
Mercedes-Benz has launched the Mercedes-AMG C63 S E-Performance in India at a starting price of ₹1.95 crore (Ex.showroom). The bookings are now open and deliveries will commence in Q2 2025.
  • Mercedes-AMG C63 S E-Performance features an advanced hybrid system, combining a 2.0L four-cylinder turbo engine with a rear-mounted electric motor.
  • Hybrid setup generates 680 HP and 1020 Nm of torque, whereas the four-cylinder motor has an output of 476 HP. The C63 S E-Performance can perform 0-100 Kmph sprint in 3.4 seconds.
  • The rear-mounted electric motor contributes an additional 204 hp and 320 Nm of torque, enhancing acceleration and allowing for short bursts of electric-only driving.
  • It is integrated with an electrically shifted two-speed gearbox and the electronically controlled limited-slip rear differential in a compact electric drive unit.
  • The AMG High-Performance battery is result of expert knowledge between the High-Performance Powertrains (HPP) Formula-1 engine shop in Brixworth and Mercedes-AMG in Affalterbach.
  • The 6.1 kWh high-performance battery weighs 89 Kgs. The low weight allows a power density of 1.7 kW/kg. It delivers a continuous output of 70 kW and a peak output of 150 kW for ten seconds.
  • Mercedes-AMG C63 features AMG Ride Control suspension with Adaptive Damping System. The car also has rear axle steering system that provides a maximum steering angle of 2.5°.
  • The C63 S E-Performance is distinguished with 83mm length increase and 50mm extended front. Signature AMG elements include a unique bonnet air outlet and iconic grille to enhance its bold profile.
