As your car is a petrol , it wont move without acceleration input. So everything is normal. Diesel car is the one that normally pulls without accelerator input.
^^ nah , it's not true. Even petrol cars move without pressing the accelerator on flat roads not uphill which diesel can easily do because of the low end torque.
@ OP - don't worry , it's not a problem. Try in 2nd gear , it should crawl around 10kmph. Idle rpm should be 700-900.
its really frustating to accelerte in first gear i give a little more acceleration it moves back and forth and if i give more race in first gear there is a voice coming from front like "cut" sorry for bad english and previously i drove wagonr i dont think there is a difference btn the two
The general character of a maruthi petrol engine is power low end torque. Ertiga diesel has very good low end but ertiga petrol struggles. you have rev a bit in 1st gear to keep it in power band
hi thnx but can you tell me how much rpm should i use in first gear without taking "jhatka".1 more thing yesterday was the first day of my car at night while i was driving i gave a little more throttle in first gear it gave a jhatka u know what i mean some cut cut like voice came from front is it a problem clutch needs adjustment?
I feel as you car is new.It needs propers run-in.As you follow proper run-in period for 1k issue may get sorted out.As far as swift petrol is concern no issues of low end torque i came across.Yes its doesnt pull strongly from 1000rpm but after 1800 rpm acceleration is strong till redline.HAPPY REVVING KSERIES.
thnx bro but is this engine knocking normal? i mean the sound it makes i dont think its normal it should only push back if i give more acceleration in first gear but no sound should come out
As far I know Swift and Ritz share same engine. I have Ritz Vxi which easily moves on releasing clutch only in 1st gear. The rpm of the vehicle while starting from garage remains 1000 but after driving for sometime [ when engine warms up to optimum level ] it settles down to around 700. Nevertheless it starts in 1st gear without application of accelerator. On a slope it requires the clutch to be placed at biting point and a bit acceleration.
- Is it from a single tire or all 4?
- at all times or during few occasions?
- at all roads or only at certain bad stretches?
- how far you are sure it is from tires only?
