Maruti 800 Headlamp Upgrade - Need Help
You can upgrade your head lamps to 100/90.
You will get separate wiring kit. Wiring kit costs from 600 to 1200rs depends on the company (make). Bulbs each would cost 150.
I would suggest Minda,Philips and roots wiring kit, bulbs you can go for Philips, Osram or Hella.
Thanks a lot for the info :) also any idea where can i get this installed in bangalore?? shud i go for JC road or is there any better place?
varun
I read that alternator upgrade is necessary to get the lights bulbs 90/100 to work
is relay and wiring ok for the performance
my M800 is 2000 mpfi standard model
If you don't have any other accessories, you can use 1000/90 bulbs it wont need a alty upgrade. Also your car doesn't have a A/C you can upgrade the lamps.
Go for Philips or Bosch wiring kit and relay.
Thread Starter #40
Wow! what an upgrade. The road is really lit up very well. Can you post a pic of the difference between old & new. Just curious to see it.
It really looks good when the weather is good.The whiter light does suffer from problems in the rains though.What is the cost of the bulbs and is it a direct fit?
