Is Your Vehicle E20 Fuel Compliant?
Hubli
But this video is in reference to E85 fuel. We are far away from that. I don't understand its reference here.
Do you mean to say similar changes are required for an E20 ready car, and a kit won't do, at all ?
Sorry I forgot to give the context for that video. Yes, he has given details about what are all the changes required to make flex fuel compliant car and I believe it applies to E20 as well.
Thread Starter #17
mayankdixit
kanpur
It looks like it's very difficult to convert a car engine flex fuel compliant just by using a small kit . Lot more parts need changing.
Thread Starter #19
mayankdixit
kanpur
I raised query with all three PSU oil companies regarding the ethanol ratio in their premium fuels. Yet to get any response from them.
I can't understand why so much secrecy around the exact constituents. It should be openly displayed on web for any one to access.
Biggest puzzle is why are all the OEMs totally silent on this topic. Why are they not shouting from the rooftop against it. After all it's their engines which are going to get damaged, isn't it ?
What am I missing here ?
Thread Starter #20
mayankdixit
kanpur
Some facts understood so far:
1)
Ethanol actually has lower energy per unit volume than petrol. Means 1 ml of petrol is more energy dense than 1ml ethanol. E20 petrol will have a fuel efficiency of 5 to 7 per cent less than pure petrol.
2) Just to explain, any car running on pure ethanol will deliver a fuel economy 30 to 35 percent less than a pure petrol vehicle. Moreover the power and launch and explosivity when starting movement, will reduce with ethanol.
3) Current E10 compatible vehicles cannot take more than a 10 per cent blend as there are material compatibility concerns with parts that come in contact with fuel.
4) There are design and material changes required to adapt to E20 fuel.Rubber and plastic,hose pipes and washers and injectors may get damaged with E20. Metals may not be affected.
5) Indian auto industry is still working to implement E20 material compatibility for new vehicles from April 2023 onwards.
6)
Petrol PSUs have still not made it clear that will they provide separate E10 dispensers from April 2023 onwards for cars which are E10 dependent.This is very worrisome.
deville_56
Reply from BPCL:
Please be informed that the quantity of Ethanol in normal and Speed/speed 97 petrol is the same. Thank you.
Reply from HPCL:
Dear Customer, We would like to inform you that the normal and Power95 petrol contains the same quantity of ethanol. Currently, ethanol is blended in MS from 5 to 10% and 20% at some select Outlets. Thank you.
Do any of you guys know the content used in XP95 from Indian Oil? My nearby station has it available and it costs Rs. 7 more then normal petrol. I haven't used it or may be once or twice only but if it doesn't got ethanol in it then I'll glad to pay the premium and use it instead.
As far as I searched around, all the fuels come with ~10% ethanol, be it regular, or speed/speed 97(BP), XP 95/XP100 (indian oil), Power/Power99. The only difference is octane rating and a few additives.
Mostly of the articles say; using a lower octane fuel than what is recommended by vehicle manufacturer could cause damage to the engine, whereas higher octane rated fuel may provide better performance but wouldn't hurt the engine or any other parts and we'll be spend more money on fuel. Luxury car owners use high octane fuel to prevent misfire, injector cleaning and ignition coil faults because issues are expensive to resolve otherwise.
Using a 100 octane on an activa will surely destroy the engine in the long run as the engine wont be designed to withstand the additional heat.
Hubli
Damn. Guess we have no better options then what is made available to us. :frown:
Well I did some research again and people around different forums say higher octane fuel doesn't effect the temperature or it may run cooler in some engines because of its ability to sustain high levels compression and heat before it ignites. High compression engines require high octane fuel to prevent premature ignition and engine knocking. However, low compression engines won't benefit much from high octane because there is no threat of engine knock taking place but performance improvement we see is because of the additives used in the premium fuel removes the carbon deposits. The same can be achieved by using normal fuel and adding fuel additives once a in while.
Higher octane=higher running temperature? fallacy?
Does Higher Octane Fuel Burn Cooler?
Which Octane runs cooler??
Thread Starter #25
mayankdixit
kanpur
So far these are the cars which are already E20 compliant:
New i10 Nios
New verna
Toyota Ganza,Urban cruiser
New Tata Tiago,punch, Altroz, Nexon
New Ignis, New Baleno,Vitara
All BMWs 2023
All Mercs 2023
Skoda Kushaq,Slavia new 2023
New Volkswagen Virtus,other current models like Taigun 2023
I request members to add to this list so that we may know the present status of market. It will help Members before taking buying decisions.
Thread Starter #26
mayankdixit
kanpur
No one is paying attention to the warranty aspect of new cars. In actuality if you buy a new car today and just tomorrow if something goes wrong in the car engine, maybe even some manufacturing defect, you will be left hanging !!
Why, because your warranty is null and void. Because it's specifically mentioned in the manual if you fill the wrong fuel then you are responsible for it, not the OEM.
E20 if you fill in a new car today, which is Only E10 compliant then your warranty is null and void.
So think twice before splurging money on new car if it's only E10 compliant.
Or choose from the list of cars given above.
Hubli
These are the fuel recommendation screenshots taken from Swift Dzire Tour S and Grand Vitara manuals. Former is E10 compliant and latter is E20 but it sounds like they haven't done much changes to the internals. May be just a ECU update, a sensor for ethanol content and some test drive with E20 fuel to ensure it runs (No matter what happens in long term) and let owners decide on drivability and/or fuel economy of their vehicle. "The vehicle may also be plied with blend of no more then 20% ethanol". This means the manufacture hasn't done throughout analyze of E20's ill effect on engine parts so they used word "may" instead of "can" and does "plied" means we cannot use E20 regularly as it can deteriorate some parts? Damn, these companies have become so incompetent and only care about sales. They are least bothered about products they sell or the durability of that product.
Thread Starter #28
mayankdixit
kanpur
People are getting confused between octane rating and percentage of ethanol in fuel.
By increasing ethanol content, octane rating of the fuel can be altered, but ethanol mixing and octane rating (RON 95) are NOT one and same thing. You can have a higher RON even without ethanol ( E0)
Hubli
Yes sir, people are getting XP95 as they think it has low ethanol but it is misconception because ethanol can also increase octane rating. i.e E85 (85% ethanol) is 108 octane!
Soon I will be checking percentage of ethanol content in regular and XP95 petrol and post pictures or video here. Method as follows: Pour 100ml petrol in a 100ml measuring jar and add 10ml of water. Mix it well and keep it stable for 24 hours. Next day we'll see clear liquid being settled on the bottom of the jar. In that 10ml is the water we added and anything above (upto the petrol line) shall be ethanol + additives.
There are plenty videos on Youtube about separating ethanol from petrol but do note that octane rating will be dropped drastically so we have to add octane boosters. People who use chainsaw, lawnmower and etc machines (small petrol engines having carburetor), remove ethanol from fuel before using it but for car and bike owners this method is not feasible and too risky.
Thread Starter #30
mayankdixit
kanpur
4th pump attendant said something which was even more alarming. He said that fuel which I am filling in my vehicles is already E12 to E13 !! I don't know how much of that is true, but I got so scared that I ran away from that pump as fast as my car could take me.
I was lucky that at the 5th petrol pump the pump manager himself came to talk to me about E20. He said that so far it's only E10 but the premium speed and RON95 fuel is E13-14. That confused me even more
It seems my fears are coming true. All along I was getting signals that premium fuel has even higher % of ethanol. It seems this was true all along. Today just on a whim, I filled Indian Oils' XTRA PREMIUM petrol in my Figo. Now the car engine instead of getting smooth has started misfiring badly. On complaining to the manager,he repeated the same above quoted line.He simply said it's not meant for my car. And mind you this time the pump and the manager were different.
Idling is normal but misfiring on acceleration. Worsens if accelerated hard.
Luckily it just 5 litres petrol. I will fill up the tank with normal petrol , dilute the premium portion and see.
