Installing Basstube in Chevrolet Cruze
TN75
So i have decide that on my tight budget i'm going to change all four doors stock speakers and install jbl coasxial speakers model:Jbl CX63SI and bass tube of JBL 1300t with pioneer amplifier.
So this setup will give me clarity sound plus good bass in my car ??
Yes good choice. Make sure your amplifier gives output of 75 watt RMS or less at the same Ohm rating.
Thread Starter #17
Ranchi
Where can i check 75 watt rhm ??
And what is 2 pin or 4 pin in amplifier can you explain me and which pin will suit my system ??
TN75
Select a 4 channel Pioneer amplifier and check that amplifiers RMS ratings. It may be 60 watts per channel or something 80 Watts etc. You need max 75 watts , don't go more than that.
By 2 pin and 4 pin I'm assuming you are talking about 2 channels and 4 channels.
Thread Starter #19
Ranchi
Ok thnx for the info bro.
2 channel or 4 channel means 2 or 4 speakers ??
And amplifier should give per channel 75watt not more than ??
And how can you say that 75 watt is max what does it mean becoz my jbl speakers if 300watt.
TN75
First of all , never see the Max watt rating for either amplifier nor speaker. Always see only the RMS rating. Your speakers are rated at 75 Watt RMS , so check 4 channel amplifiers that can give out 75 Watt RMS or below per channel.
4 channel amplifier means you can connect 4 speakers to it.
If you are connecting your stock head unit, go for amplifiers that have high level inputs. Mostly Pioneer amps have this option.
hitler ruled country
I am changing my head unit. Which is best.
caska or megaaudio.. one car decor guy suggesting universal 2 din music system.
He promised me to work MID screen that shows climate control's and convince settings. He is also saying steering controls also work. What say?
Thread Starter #27
Ranchi
Will the box will be provided by any local accessory store and will give good bass than basstube ?? Becoz i have no idea about basstube bass and box woofer bass.
Which is good one ??
As i think that basstube will take more space than wooferbox??
Kuwait City
Will the box will be provided by any local accessory store and will give good bass than basstube ?? Becoz i have no idea about basstube bass and box woofer bass. Which is good one ?? As i think that basstube will take more space than wooferbox??
Basstube creates boomy bass (doof doof), the kind you might have heard in those fancy cars, the thud can be heard outside. The box type is usually SQ friendly and gives a soft deep bass. Make the choice based on your taste in music rather than the space consumption. You can get subwoofers that comes with a factory fitted box enclosure. If the prices are appealing you may have a look at such models too.
