4th service (paid service) 32540 kms
Complaints i had
Clutch would get hard on long journeys,clutch master cylinder was changed on a non routine visit to service center,i was asked to pay for it as car did not have extended warranty(i had asked for it & was under assumption it was paid for also. But they did it for free, this time around as problem repeated,they told me the clutch pressure plate had a bolt in it going weak causing the problem!
Rear power window switch would not work(fixed)
Parts changed/charged
Engine oil 5.7 litres, 269.8 per litre -1538
Coolant 2 litres,3.1.3 per litre - 602.5
A/c neutralizer WEC- 650
Distil water 2,18.3 per bottle - 36.7
consumables - 200
Switch assembly back up lamp
(defective part gearbox sensor)Not covered by warranty - 1558.2
Switch assembly-Power Window - 227
Filter cartridge - 1736.4
Filter air cleaner - 280.3
Service kit oil filter 363.7
washer - 26.2
Plug oil drain - 26.2
Grease ,caliper guide rod - 149
Total - 7510, Tax - 965.7 = 8647.83
Service/labour charges
Outside job/others - 50
Periodic maintainance service- 1480
Coolant change - 210
Caliper pin greasing X 2 - 440
front brake pad cleaning - 315
Switch assembly back up lamp(unroutine/defective) - 176
Power window switch - 132
fuel filter - 176
Total- 2979 ,Ser tax-368.2, = 3347.2
Grand Total 8647.83+3347.20 = 11995
Remarks/Feedback - My car clutch issue is being pointed out to a weak pressure plate in the clutch.Hyundai had changed clutch master cylinder for free as they assumed that was the prob & i told them i wont pay for it,this was done many thousand kms before this service.
During service inspection they noticed gearoil on certain places & concluded that the threading on a gearbox sensor had gone & it was leaking oil,i told i wanted it covered by them as its a defective part,as negotiations failed,i had to pay around 2000 cos of it,Have to say Hyundai parts arent really that high on quality these days.
Wheel alignment was'nt done as tires seem to have another 6000kms left in them,will get alignment done outside at fraction of the cost anyhow!
Additional modification done to headlights 2 months agohttp://www.theautomotiveindia.com/forums/accessories-modifications/1624-hid-xenons-headlamps-discussions-queries-71.html
