If you drive the car in a lot of traffic like me you will have had this experience. Standing in traffic with the foot on the brake, there is a sudden drop in engine rpm and the brake pedal sinks in. This happens as a energy saving feature in an extended idle where the engine drops from 1200rpm or so to 700. But it also happens when the aircon disconnects when a set cabin temperature is reached. The load on the engine drops and the ECU reduces the rpm. Then the vacuum applied to the brake system reduces and the brake pedal sinks in
If compressors didnt cutout off, their life would be very short. In an auto climate car, the cabin temperature and humidity is just controlled more accurately.
The real question is, if I set the aircon dial to a lesser amount of cooling- being winter now, will that save any fuel- will the compressor run for a shorter time or is hot gas from the engine used to reduce supply temperature to the cabin?
Ameyam
Ameyam
![Thumbs Up [thumbsup] [thumbsup]](https://www.theautomotiveindia.com/forums/images/smilies/Thumbs%20Up.png)
I'm experiencing the same situations daily as you have mentioned.
FYI.. Dude I drive my car on JVLR in Mumbai and I don't think there is any need to explain the driving conditions at JVLR to you as mentioned that you also drive in a lot of traffic.
