I dont seem to be encountering these sticky tiny wax balls.just normal wax dust that gets off when buffing
+1 to this. I've been using Turtle Wax Hard Shell Shine (paste and liquid) for 6+ years on multiple paint finishes without this issue.
To add to that, another question. Whats the correct way to apply wax?
I usually apply a few dabs of paste wax as if it was cold cream, then go about spreading with a foam pad. But these two previous times i noticed that most of the wax was actually going into the foam pad, so i just went at it with my hands. After a few minutes, i wiped off with MF cloth. A couple of times i used the cheap chinese polishing machine i have as well. However with turtle wax, it began to dry up even before i got back from coating the next panel. Neither hand application nor machine seems to improve gloss in any way
Ameyam
Well, the best way to apply wax is to get rid of those foam pads, they are far too aggressive for wax application. Simply put, their roughness removes a lot of wax during application, before it gets the chance to set. Don't even get me started on using an orbital polisher for wax
The best way to apply wax is either with clean hands or nitrile gloves (allows you to feel where there is/isn't a layer of wax) and massage a thin layer of wax onto the paint, following the body lines. It should become hazy/flaky relatively quickly, at which point gently remove it with a clean MF cloth. The surface should be left glassy and smooth (gloves should slide easily). If there are patches, you can apply another layer on top (it'll only stick where there's no wax).
I use Vista car polish (liquid)
I apply it onto a plastic bag (don't use a cloth or a sponge as it absorbs the polish) and then spread it on a panel.
After a minute, I rub it with a cloth.
All this is done after I wash the car.
I'd like to point out something key - polish and wax are NOT the same thing. Polish is a fine abrasive that removes a layer of clearcoat to create a smooth surface, using it regularly will ruin your paint in the long-run as there will be little/no clearcoat left. Wax is a clear protective layer you apply to protect your paint, while increasing gloss.
You should not be rubbing polish when it is dry. The abrasive particles coagulate and will be far more aggressive to your paint. Honestly, you shouldn't let polish dry on your car in the first place.
A plastic bag is likely the worst applicator material, it is far too non-compliant and will very easily scratch up your paint. If you want to avoid the (negligible) absorption of cloth, use a pair of Nitrile/Latex gloves.
Finally, you should wash the car thoroughly before doing any paint work (polish/wax/sealant/etc.), otherwise you will just be carrying dirt around the paint and creating scratches.
