Partial Suspension Overhaul (January 2023):
Long due work is finally done, that is replacement of front worn suspension parts. The car had following issues from quite a while and of late they had become unbearable: 1. Squeaky noise from driver side strut mount when the steering is turned to full right. 2. Sagged and stiff suspensions. 3. Knocking noise from the front while going on potholes & speed bumps. 4. Rubber boot of stabilizer link and tie rods were torn and ball pin had partially play.
Last month I took my car to Honda ASC for selective servicing (Transmission oil, brake fluid and coolant replacement) and asked them to check suspension condition as well. They did a short test drive on a good but busy highway so above issues were not much noticeable. I left the car at ASC for servicing and returned back in the evening. They checked the suspension parts under lift and noticed some play in ball joints as well as in steering rack. SA said it will be fine for few thousand kilometers but still I insisted him on getting partial suspension overhaul. However, major parts will not be in stock with service center and will be ordered upon request with 50% advance payment. We selected following parts and the total estimation was 38k excluding labor. Front strut assembly and strut mounts, rear shocks, tie rods (inner and outer), stabilizer links, stabilizer bush and several nuts for these parts. Made 15k advance payment for new suspension parts and 3k for servicing as mentioned above (Invoice attached below).
Last week I got call from SA and he said all parts have arrived except rear shocks (approx 6k less from above estimation) and asked me to bring the car for installation. Dropped my car at ASC and returned next day to pickup. It was ready by afternoon itself and total payable was 35.7k which includes 4.5k for labor (Invoice attached below). They did wheel alignment and washing for free of charge. On first glance I was shocked at how much the front end was lifted (Almost 2 cm higher then rear) and all these years I was struggling with a sagged car. About 90 percent noise is gone and remaining is from rear suspensions, though it is very minor and can be heard only when windows are opened. The car rolls smoothly on uneven roads with 2nd or even 3rd gear; before I used to slow down and down shift on potholes & speed bumps.
Now what I disliked is sagged rear suspensions which has somewhat spoiled the aesthetics of the car. Upon checking invoice later, I noticed that they have installed strut assembly of facelift model (51610-TM2-K54) and I thought it lifted the front end because facelift model has higher GC but later when I checked several videos on youtube (i.e
here is one), even correct strut assembly (51610-TM2-K01) has lifted the front end of the car just like mine. SA said they have used latest or upgraded struts and it doesn't harm anything and will look normal when rear suspensions are also replaced. Still I have following concerns, please let me know if you guys know about it: Is it okay to use strut assembly from facelift model? does it get settled after sometime? Does it cause any problems with other parts?
My friend suggested me to get rear coil spring buffers until I replace rear suspensions. It will raise the height and normalize the look of the car but may cause stiffness so it is a little trade off. Another option was to replace only the coil springs for now but another friend said old shocks will over compress the new springs and again cause stiffness. So I felt going with buffers was a better option and I opted for AMT brand ones on Autotrends for Rs. 900/- instead of 2.2k Rogerob on Amazon. Buffers are still on way so I will make a post on them later.
Here is how my car looks after replacing front suspension parts:
Gap above front and rear wheels (2-3 cm difference):
After installing new front suspension parts:
Selective Service Invoice:
Front Suspension Replacement Invoice:
