Honda Motorcycle & Scooter India (HMSI) has launched India’s first 300cc flex-fuel motorcycle: Honda CB300F Flex-Fuel. It is available at BigWing dealerships for ₹1,70,000 (Ex.showroom, Delhi).
- Honda CB300F flex-fuel is equipped with a 293.52 CC, oil-cooled, 4 stroke, single-cylinder PGM-FI engine compliant with up to E85 fuel (85% ethanol & 15% gasoline).
- The engine delivers 18.3 kW of power and 25.9 Nm of peak torque. It is mated to a 6-speed gearbox and also gets an assist slipper clutch that requires less force enabling quick gear shifts.
- Honda CB300F flex-fuel is equipped with disc brakes at both ends (276mm front & 220mm rear) with dual-channel ABS and Honda’s Selectable Torque Control (HSTC) as standard.
- The motorcycle receives an all-LED lighting system, Golden color USD front forks and 5-step adjustable rear mono shock suspension, in addition to a fully digital instrument panel.
- There's also an Intelligent Ethanol Indicator, which glows in case the motorcycle is filled with higher ethanol content gasoline (more than 85%).
- Honda CB300F flex-fuel will be available in a single variant and two color options: Sports Red and Mat Axis Grey Metallic. Bookings are now open, and deliveries commence from the last week of October 2024.
