Re: How To Drive and Maintain a Diesel Car?
Thanks for correcting buddy,I'll be remembering this from now onwards.
In other words when we push start the vehicle,the gearbox works as the 'external aid' that time.Right?
Yeah it is better than the Honda i-vtec and Maruti Suzuki 'K' series engines in low end.Other petrol engines are still having better low end pull.
+100,turbo lag is really nothing,you just need to know how to work the gearbox.
This depends on the powerband.Punto's engine is good at higher middle range while Innova takes the beating there.And any car which is having powerful top end but less powerful lower end always needs a lot of gearshifts.Especially while moving below 60 kph or in city.
+100,I was also trying to explain the same to him..
Turbocharger is running at all rpms. A turbocharger is a high precision piece of engineering. And it starts rolling at slightest gust of exhaust gases. But the pressure developed by it is significant enough only at around 1800 rpm (or above this rpm).
You are right Vipul. "Cranking" means turning the crankshaft of the engine with external aid (by starter motor). Sometimes its done by pushing the car. Cold start is just a condition. You still have to crank it to bring it to life.
Not true for all diesels. Yes, in my Punto, the low end is terrible. But in mHawk, TDi, D-4D, etc... even the low end is great. Just that, you wont get the kick of the turbo, but it wont be lethargic.
To overcome turbo lag, all you have to do is be in the right gear at the right time. Its not a big deal as it sounds!
For example, Innova & Punto. You have driven both. Punto needs more gearshifts than Innova.
There is nothing wrong in what you are doing buddy. Only thing is, you turbo must be in hibernating mode now, since you have rarely used it!
Once in a while, you do need to rev it. Dont unnecessarily keep revving it for long durations. Dont even rev it till 4000 rpm. Short bursts till 3000 rpm once in a while will also do. You have a turbo diesel, use the turbo !!!
