Let me rekindle an old thread and bhvm look forward to your inputs :-
I am looking for a simple hybrid solution in which my existing 12v inverter can be also charged by a solar panel - not looking to make extensive investments.
Some facts :-
Load is approx 200-250W (varying outdoor LED lights) - I need my outdoor lights to remain on whole night and was wondering if it would be completely powered by solar itself.
Not looking for expensive end to end solutions but something simpler which can work with the existing inverter - a hybrid solar controller type may be.
Suggestion welcome :- Also keen to understand if there are any specific brands/types of panel which have better efficiency than the rest and something thats easily available in india.
Some facts :-
Its very easy to add solar to your Existing inverter. Once enough panels and battery capacity is installed, any load connected to Inverter is effectively solar.
What you need is a solar MPPT controller like this-
MPPT Solar charge controller India | PWM | Hybrid
https://www.youtube.com/watch?v=Iq6U6sBJV7k
https://www.amazon.in/SYSTELLAR-Solar-Charge-Controller-Autoselect/dp/B00JOCHWLA
https://www.amazon.in/Power-Saver-Systellar-charge-controllers/dp/B00PIH1HXY
Never buy PWM solar controllers, Only MPPT.
The setup will be like this-
Connect Solar Panels to MPPT controller. Make sure wires are thick (6mm or Better) and shortest route without Joints.
Connect MPPT to battery. Configure the controller according to your battery type and preferences.
Please note that this setup is Mainly geared towards-
1.Providing Stability to Power setup
2. Longer Battery Backup and Longer Battery Life (due to battery being always charged and prevent deep discharge during Load shedding)
3. Ability to fight multiple days of Power cuts (Depends on Battery capacity and Panels).
However, the setup does not cause monetary savings as much because there is no way to measure and deduct solar energy units from your bill.
Some tips-
Install double the Requirement of your solar Panels as these things are very inefficient and do not work at 100% output most the time.
Inverter, Battery and Transit losses will add another 30~40% of Inefficiency. Which means, the Load working at night will be less efficient. Solar is best used during day.
Your Load- 250W for 8 hours= 2000w
Sun time Production Average, 5 Hours, So Panels needed- 400W to 500w
Battery needed (3 days Blackout, Cloudy days)- 500AH , 12v
Battery needed (1 day blackout)- 165 AH, 12v
Add about 50% to all above for inefficiency.
