Good Write up, really informative
I would appreciate if you could clarify my doubt in regards to kerb weight of aspire, as you know aspire is having lesser kerb weight while comparing with TATA zest and bolt, according to you how safe is the structural build quality of ''Aspire'' as kerb weight has a lot to play in a cars safety in an unlike event of collission. mere air bag & ABS cant make it full proof safe cars without a good good built.
Safety of the car is primarily from the Chassis, if the Chassis is strong and if its designed to retain its shape even when Force is applied there starts the safety Novelty.
Then comes the front crumble Zone, all modern cars have front crumble Zones,expensive cars have these in their rear as well like in cars of D segement and C+ segment like Fluence,Octavia,Jetta etc.
The crumble Zone can absorb the huge forces and distribute it into some other direction rarher than the drivers or passengers direction, crumble zones are usually located just on the back side of engines or between Steering coloumn and cooling ducts and AC components,
Then comes the extra weight from sheet metal,exterior body,and frame,
Then comes ABS,AIRBAGS,SEAT BELTS,
Then comes safery assist systems,
Regarding Figo Aspire the chassis is said to be made of 45% high strength Boron steel thats light weight and yet as strong or slightly stronger than regular steel,so Ford saved some weight there,
Then they saved weight in sheet metal. The doors usually in Ecosport,Fiesta,etc have dual layer of metal, while Aspire has just one layer, so in case of side impact its not as safe as Zest, but the B pillar which is a chassis extension will stay strong, so its still far from fatal,
Then other weight reduction is at the boot,its super light and hence cannot take much impact,since Aspires chassis is one thats of a hatch back the rear section could be its weakest point.
Since Aspires chassis is said to be the strongest I believe that it will stay as it is even after impact, the Aspires chassis is the old Fiestas chassis, ie current Figos, and this one and the VW POLO are the only cars that passed UN56 safety test in India without Airbags, thats the reason why I feel Aspire is as safe as Zest despite being light,the Zest too is well built and could be smart in safety,
