Force Launches "One" - The 140 BHP SUV (4x4, ABS & Base 82 PS Versions Now Launched)
Mysore
Re: Force "One" the 140 BHP SUV to Launch in August
the car looks funny form the angle OD team has taken the snap. awaiting interior shots
See it to believe it: Mr.Bacchan is the brand ambassador.
Indore
Well nor the car nor the brocures have hit our showroom !! it was a soft launch today !!
Mysore
Mr. AB being brand ambassador doesn mean it will do well.. remember versa :P
but this product looks decent.. hopefully it will do good by itself
without abs and 4xf approx 12:65 on road mumbai. Lets see.. I think it is going to fizzle out
And has the car reached to your dealership?
The company showroom in Pune is not ready yet. By the current status, looks like it won't be ready for next 20 days at least. [surprise] So can't see the car in near future at the showroom.
Mysore
and i doubt if they even have a showroom in bangalore. atleast iv not heard of it. FM have hurried n launcvhed.. they could have launched it sometime in sep or so. with all current 22 dealerships ready..
Yeah. There are presently 22 Dealerships and 22 more are expected to open by next year.
The work on showrooms is running behind schedule. Anyway the SUV was to be launched earlier but kept on delaying. They had to do a soft launch today to gather interest and queries.
Car does not look like a winner and settles somewhere between a Ford Endeavor and Xtrail. The thing to be seen is how does the heart perform and drivability.
Force One Features:
- 141 PS/320 Nm with BS4 and BS5 compatibility
- Can run on deserts and high altitudes with the same zest
- Can start in -21 degrees centigrade
- Has a Dual mass flywheel
- Has a low friction gearbox high torque density
- Chassis gets CED coating, first in its class (finding out more)
- Handling also tested on British speedways; Lotus Engineering helped tune the suspension for India
- Rack and pinion steering
- 30 stage welding process for body
- Three row seating
- Armrest with cup holders in the second row
- Third row folds to generate more boot space
- Electronics validated by Mercedes Benz
- On board computer monitors 15 process
- The spare wheel is fitted under the body
- A leather wrapped steering is present
- Audio controls are placed on the steering wheel
- Each rows has dual Aircon vent
- 4×4 version hits the market by March 2012
- ABS variant will come after the 4X4
Force One Technical Details:
- Force One has class leading ground clearance of 205mm
- Fuel Tank capacity of 70 litres with a seating capacity of 5+d and 6+d.
- Force One’s External dimensions are Overall length (mm) – 4860, Overall width (mm) – 1780, Overall Height (mm) – 1885 and Wheel Base(mm) – 3025mm
- Force One Brakes:
- Type – Hydraulic Vaccum assisted with LCRV
- Front – Ventilated Disc with Twin Pot Force piston Caliper
- Rear – Drum with Auto Adjuster
- Parking – Mechanical Linkage type
- Force One transmission:
- Model : G 32/5(Under License with Daimler A.G.)
- Type : Synchromesh Gears
- Gears: 5 forward and 1 reverse gear.
- Its front suspension is independent double wishbone and a coil spring with gas-charged telescopic shock absorbers, as well as an anti-roll bar. Its rear suspension is made up of a multi-link with pan hard rod & coil spring with gas-charged telescopic shock absorbers as well as an anti-roll bar
- Force SUV is capable of producing 141PS power and torque of 320Nm@1600-2400rpm. - The vehicle is powered by 2.2 litre common rail diesel engine similar to the ones used in - Mercedes C Class (C220 CDI, C250 CDI) but adapted to the needs of an off-roader.
- Features like driver information system, cruise control, audio control mounted on steering & dual AC vents are present on the One.
- Force One SUV will have OSRVM side indicators and leather seats. (Info: Indian Autos Blog)
Bhopal, India
dude can anyone confirm if bookings or deliveries started??
Delhi - Ex showroom price - Rs 10,65,219
Mumbai - Ex showroom price - Rs 11,11,382
Cool
Looks quite specious and decent IMO suv should have aggressive monster look
I like everything I see on these pictures as well as specs. If the SUV is as good as these pictures and specs suggests in real, it is worth considering. Price is not bad either. Though the no-ABS is a downer.
