The advantages of fog lamps are only apparent - as suggested by the name - in extremely foggy, rainy/snowy or dusty conditions. Basic explanation is below:
The main difference compared to the headlamps is their positioning: Low and at the corners of the car. This is because is allows the beam to illuminated the surface of the road effectively in situations where the main lights would simply be reflected by the moisture/dirt in the air.
However, the housing is also shaped such that it 'spreads' the beam of light, as compared to 'focusing' it like headlamps do.
It is for this reason that you should NEVER use foglamps in combination with your full beam lights, because full beams will simply be reflected back at you and (according to Biology your pupils will contract) you will be unable to take advantage of the sight provided by the fog lamps!
It also explains why fog lamps are never white, because white gets reflected by moisture much more easily (due to a wide range of light frequencies present) than a tinted colour such as blue or yellow.
In conclusion, I urge you to buy headlamps, you never know when they come in handy, and you can even use them creatively like "K!NkY" to help you in other situations! Don't get obsessed with trying to buy the most powerful ones though, just make sure that the person installing them knows how to align them for max. effectiveness.
Ps. I really hate it when people don't know how to use their fog lamps properly and just turn it on/off as they please to show off, rarely turning them on even in the typical zero visibility Delhi fog!
