Guyz - I am back again with another strange, unique and inexplicable issue. Let's see how many around here is able to find a fix for it!
By seeing the thread title, I am sure many would jump in to bombard me to accuse on Figo's Music System. But just hear me out. As many of you must know, Figo comes with a Best-in-Class Audio System for a OE one, at least, I have not seen a better one. Not that it's THE BEST and doesn't need an upgrade at all, but probably more than enough for a OE one. Of course, a true audiophile won't be contented, yet won't complain either. I am not an audiophile, but want music in right mixture with pleasing quality. So, I am much happy with it's output and feel it's just right for my taste.
Now, straight to the issue... I really don't know how to put this across, let me try my best.
The sound quality is generally good to great and especially with USB Playback, which is OE again. However, at times, I feel the sound quality isn't consistent. Maybe deteriorating or less punchy or not so crisp or clear enough as it normally be. Confused? The sharpness in the music/vocals felt to be attenuated or probably flat and so the bass/punches too. Yes, the Volume, Eq. and all other setting remains the same. To make it more mysterious, it gets back to normal when I format / reload the songs in the Pen Drive and play it again. But, at the same time this issue would occur again, when I disconnect the pen drive, like earlier. So, after it's disconnected / connected to Laptop / reconnected to HU, it either works wonder or bad. Any clue till now? Or gone mad???!!! Again, this is very very minute for a stranger to notice, but I could as I have been with it day in & out. Moreover, unfortunately, I am quite sensitive to sound and smell![Frustration [frustration] [frustration]](https://www.theautomotiveindia.com/forums/images/smilies/Frustration.gif)
Here are my thought:
I am sure it's a rare kind of issue for one to experience. But, if someone as lucky as me, can throw some light. Or different views to check on other parameters or at least, a best way to get this explained to FASS. Sorry guys, it's a bit tricky, but that's nothing for TAIgers I believe![Wink [;)] [;)]](https://www.theautomotiveindia.com/forums/images/smilies/Wink.gif)
- Most of the songs are in 230-320 kbps / 44.1 Khz sampling. So, sound quality isn't a question and digital files won't deteriorate. Moreover, the same files play well and dull in different situations. So, nothing about files.
- Tried different Pen Drives (8 GB), it works the same. So, Pen Drive issue ruled out as well.
- Formatted the Pen Drives in different formats like FAT32, ExFAT, NTFS etc.
- Loose connection in USB Cable? Possible, but tried shaking / pressing it during playback, no differences / disturbance felt. So, I think, it's working fine.
- Speakers? All the speakers were changed once and the rear ones twice due to the Squeaking Noise issue I reported earlier (http://www.theautomotiveindia.com/f...es-unsolved-dealers-any-brand.html#post307707). Also, once I reported that the RHS is felt to be slightly lower than the LHS and they tried fixing it by replacing the speakers. Though both the issues (Squeaking & RHS) weren't solved, the speakers were just changed. So, I won't blame the speakers.
- So then HU? Could be... Remember the RHS issue? Even if the RHS isn't working together with LHS, it can deteriorate the sound quality. Isn't? But, if that be the case, here comes the most critical part of the issue... How to demonstrate this to the FASS as the issue isn't permanent or on/off. Moreover, making FASS to understand an evident issue itself a nightmare, then imagine an issue of this kind!
