I really hope you're not trying to apply the same concepts as motorcycles to cars, because although the basics are the same, the mechanisms are entirely different! A motorcycle does not have nearly the same level of heat isolation as a car, simply due to space restrictions. In a car with the brakes locked, the only source of heat is the brake disc/drum itself, as caused by the friction between the locked brakes and the rotating wheel. It is nigh on impossible for this heat to cause the wheel to collect head, and even less likely for this to heat up the hub! And when you're saying "Wheel hub" what you are trying to refer to is actually the "Brake drum". As I'm sure you're aware there's a difference between Disc brakes and Drum brakes. The hub is actually the centermost part of a wheel assembly, it contains bearings to facilitate the rotational motion of the wheel, brake disc/drum, etc. while connecting them to the axle.
Thanks to Wikipedia that we can get so much information with the technical words.
Ps. What you are referring to as a "Wheel disk" is actually the rim itself.
And anyways, drum brakes are less susceptible to heating than non-ventilated discs as found on most small indian cars.
Rally cars' brakes undergo massive punishment, we almost have to replace them after each stage of the race, yet there is absolutely no heating of any part of the wheel assembly due to this!
