Custom Modifications with LEDs
Faridabad
Which bulb are you referring to?
If you are talking about white-light halogens, they cost around Rs.500 (or less) for a set. The light output is very less and they are good only for showoff purpose.
NA
Re: Budget Audio Setup For Sail U-VA
Using this thread - can someone suggest led DRL for Sail UVA hatch, one year old. Pl share model, prices and where from best available Mumbai. Also should this be done at local mechanic - is it okey to fit locally
I am looking for contiguous lighting up as against the dotted light up if possible
NCR
For continous or full lighting (rather than partial dotted lights), you can try universal COB LED DRLs available at ebay.in. They will cost upto Rs. 300 for a pair and have great illumination for smaller range. You can do this as a DIY and even get this done locally by a mechanic. Be sure not to tap the existing wiring and ask the mechanic to make a seperate connection from battery (with a proper fuse) with a seperate switch near the dashboard to avoid warranty problems.
I doubt whether branded DRLs are available in the continous lighting type you are looking at. So chinese is the way to go I feel.
Kochi
Does anyone know where i can find projector headlight for maruti baleno 2015.asking this scince i booked the zeta variant which does not have projector headlamps.
NCR
Best option would be the direct fit - Alpha's headlights. Ask your Nexa dealer about the price, but they would be expensive than aftermarket or retrofitted ones.
Panchkula
Want to build a switchback led drl for my car
As the title specifies, I want to build a switchback led daytime running light for my alto k10 aka the pocket rocket. I have seen tutorials of people building something like this using a transparent tube, filling it up with some kind of a suitable liquid and the fixing two LEDs at both ends. That is good but
First, it doesn't have switchback feature(won't act as a turn indicator like the audi's have)
Second isn't bright enough to be used as a drl
And third, the intensity drops as you go away from the led..
So I have a pretty good idea on how to do it but I am facing some problems
1 I don't know how to get that continuous lighting effect (maybe a light dispersion medium would work)
2 I don't know the circuit diagram for a switchback led drl
And third I don't know how to keep it bright(I think an led strip should work)
And please put up links for any required materials. Thanks
Cheers
NCR
Re: Want to build a switchback led drl for my car
I wanted to build it myself because isme kick Hai!!! And another thing it doesn't have switchback feature
The ones with switchback feature are available, a bit pricey though. They will not look good on a compact Alto K10. Better to go for normal ones.
Panchkula
Could u pls tell me about where to purchase projector headlight and fog lamp for alto k10 affordably.
NCR
Online stores have parts at par with market prices but in case of offline shopping, you have the scope of negotiation. So, try at shops in and around your area.
