Car Scan Tool (OBD) – Queries & Discussions
Varun, I came to know about the location of OBD Port from the workshop manual of Maruti 800. I'm attaching the snapshot below.
Hi 350z ,
I checked it out I could not find any of the ports, Please find the pictures relating to that..
(sorry for the blur images, taken from my mobile)
1st 2 pic's under steering, the other two left side next to glove box..
Did you check it on co-passenger side or Driver side? Because that box looks like ECU which is located on the left.
Checked both the sides as guided by you, the 1st two pic's are from the right side other two are from left side, This is aluminum box which i was mentioning before, is that the one ?
Thread Starter #53
Just 5min. ago i got my OBD 2 . gave it tried on my I10 worked perfectly showed me all the details . But it did gave me shock when i tried to see FE it showed me 5 O_O
here some pic
I saw the same device on other forums, someone was fitting this thing on an indigo. Tech it out comepletely and post results.Good luck.
Thread Starter #56
till now i have used efficiency and torque in my android mobile will check it using laptop later . It even read my all engine problem :)
Cochin
Nice stuff out there.Keep posting more and more pictures.Is it a bluetooth enabled scanner?
And how much you've paid?
Eager to know more about them.[clap]
Thread Starter #58
yup you will need bluetooth device to connect with it . I have paid 850 . Just now i tried on my corolla it seams it can't connect :/ will look into matter . wish only i had mine safari to test
Cochin
Amit is right I think.Maruti Suzuki is using a different protocol.So OBD2 scanners will not work with a Maruti.I'm really sad[frustration]
