Here come some more information on my headset.
How is the packing ?
Following is the image of Jabra Halo packing.
The packing is wisely done and is really impressive. All accessories are inside the pillar in the center of the packing. So what all stuffs are there inside the pack?
- Jabra Halo Stereo Bluetooth Headset
- USB Charging Cable (micro USB)
- 3.5mm Audio Cable (microUSB to 3.5mm)
- Jabra Halo Carry Pouch
- Manual
How does it looks like?
How easy it is to carry around?
Well, Halo easily folds as shown below.
Once it is folded, the headset is automatically switched off. When you unfold it and put it into proper shape, it is active and is available for blue tooth connectivity.
What are the indicators available?
Inside the (left side) headset, there are 2 indicators one each for battery and blue tooth. When the headset is charging, the battery will blink in red color. Blue tooth indicator will blink in blue color when connected and battery status will be green when there is enough charge left.
What are the controls available?
This is where Jabra Halo scores! As you can see below it has a touch control for volume control which is very precise I would say. The circle button stops/plays music or helps you to take the call. If you double click it, the last dialed number will be dialed automatically. When connected with devices with A2DP profile, you can switch between tracks by double tap on volume control pad. A double tap on
+ area will skip the track to next one and a double tap on
- will move it to the previous one! These are the only controls available and you may require, isn't it?
Really intelligent and impressive design
