A 'SlingShot' From Suzuki India
Too bad looking , very skinny , not to my taste. Though the yellow one with alloys is looking okay. The alloys design is looking unique.
Ahmedabad
seems they are looking to match up the looks from FZ, copy from them their headlamps, also yellow shade looks similar to honda stunner, hope it could capture good market share, though more pictures awaited to see it in better way.HOws the meter console given?Also no disc brakes.
The Slingshot looks much better than what i expected. The yellow one with those uniquely designed alloys looks good. But still no option of discs and skinny tire makes it inferior to the others in segment.
@AMG- Nice pics friend.
sling shot specs -
Overall Height 1075 mm
Wheelbase 1265 mm
Ground Clearance 160 mm
Kerb Mass Spoke Wheel Cast Wheel
Kick and electric starter Kick and electric starter
127 kg 128 kg
ENGINE
Type Air cooled, 40-stroke, 1-cylinder, SOHC
No. no cylinders 1
Bore X Stroke (mm) 53 X 55.2
Displacement (CM3) 124 cc
Compression Ratio 9.1:1
Carburetor VM18
Starting KS and ES
Air Cleaner Non-woven fabric elemnt
Lubrication system Wet sump
TRANSMISSION:
Clutch Wet multi-plate type
Transmission: 5-speed
Gear Shift Pattern: 1-down, 4-up
CHASSIS:
Suspension
Front TElescopic, coil-spring, oil-damped
Rear Swing-arm, coil-spring, oil-damped
Brakes
Front Mechanical, leading-trailing drum type
Rear Mechanical, leading-trailing drum type
Tyres
Front 2.75 – 18 42P
Rear 3 – 18 52P
ELECTRICAL:
Ignition: CDI
Spark Plug NGK
Battery: Kick start & electric start spec: 12 V 5Ah
Headlight: 12 V 35 W/35 W
Fuel Tank capacity: 12.0
REserve 2.1
COLORS :
MEtallic Mustard Yellow
Metalllic Fox Orange
Candy Antares Red
Pearl Nebular Black
