Hello friends , completed 5000 km on odo and 3rd free service is due.
Before that i would like to discuss a few queries with you guys.
1. Planning to switch the engine oil to motul 5100 5w50. The tvs tru4 oil that the svc provide is of 10w30 grade. Is there any problem in using different grades ?
Changing Oil grade might voide Bikes warranty . Also i feel 5w50 will be to thick for RTR . Try Castrol Power 1 15w40 for RTR . I am X RTR owner and i used to use this oil for long trips and used to change it at every 2000kms. For Fully Synth try Petronas Sprinta 10w30 suits well for RTRs short stroke motor.
2. I could feel small jerks while riding in 2.5 to 3.5 k rpm at the speeds of around 40-45 kmph. What could be the possible reason? I dont think its the problem with fuel.
may e chocked fule line or Car Jet ? try cleaning carb and see if it makes any difference.
3. Vibrations are an issue and makes you feel bad if you ride a pulsar and apache back to back. Pulsars lack the outright punch of apache but they have really advanced on engine smoothness and gear shifts. Hope engine oil change might cause some relief. Any other suggestions ?
hehehehe. I am not against any brand but RTR is way ahead in terms of performance and rigidity . For hard gear shift check Clutch setting and for Vibrations :P always ride above 5k mark you wont feel any thing at all .
4. Please suggest if there are any other semi synthetic oil for apache rtr 180 other than motul. Iam sure we have many apache.ins here. So please guide.
