So finally after lot of hesitations I finally decided to go ahead and get Autorunner Coil spring assisters installed in my verna. I bought them from Mr. Darryl (contact no.9821047448) who is also the manufacturer of these assisters. I paid Rs.4300 for four assisters including courier charges. Darryl is a really genuine person and he explained me everything about the assisters when I called him up for the first time. I bought assisters for all four springs from him. The assisters size is different for different vehicles. I Got 1.5'' autorunner B3 installed in all four springs.
The installation is very easy with the rear coil spring assister installation being the easiest. the front ones need just a bit more muscle power.
I jacked up the car and sprayed some soap water on the springs and pushed the assisters in place. Its definetly a DIY job and can be done at home.
The car has completed almost 500 kms with the assisters and the following re my observations
Pros
Cons
I am not really bothered about tyre wear because of what i am getting in return for it as improved ride quality.
and, the coil springs for verna are cheaper than the assisters themselves.
Attaching some pictures taken after the installation
![Rage [angry] [angry]](https://www.theautomotiveindia.com/forums/images/smilies/Rage.gif)
Pros
- The bounciness has reduced on highway speeds and car feels much better controlled. The so called 'BOAT' feel is gone.
- Increased ground clearance
- Slightly stiffer ride quality than before.
- Slightly reduced suspension noise over bumps
Cons
- I have been told it increases tyre wear by at least 10%
- Maybe it has some impact on the coil springs
