Ultimate Guide For Maintaining Chevrolet Beat Diesel
Thread Starter #18
Kollam
Because the coolant is still mixing with oil somewhere ,maybe at the leaking head gasket !
Nice DIY on your Beat. And very apt explanation with lots of pics. Very good thread !
Are you doing it all yourself,or is that you're taking pics at the FNG while the mechanics are working over on the Beat?
No, i am pretty sure that my head gasket is not leaking and oil is not mixing with coolant. (I read somewhere that this is due to the reaction of chemicals with two different coolant types).
And YES i am doing this all by myself! [:D]
Thread Starter #20
Kollam
DIY: How to Replace Diesel Filter?
Finally, got some time to replace the diesel filter. As i was busy with some other works, i didn't had time to get this done.While replacing the diesel filter,keep in mind that you must do the 'Air Bleeding' process properly. Because improper bleeding may screw your high pressure pump.
Okay so enough talking, let's jump into the process...[evil]
THINGS NEEDED
13 mm ring spanner
36 mm socket, handle and extension
Diesel Filter
Flat Head Screw Driver
Drain pan
Jack and Jack Stands
PROCEDURE
Step 1: Jackup the rear right passenger side of the car.
(The filter housing is located under this side)
Step 2: Keep a Catch Pan under the filter housing to catch diesel
Step 3 (Optional): Remove the clamp.
( This will gave more room to remove the filter)
The filter housing.
Step 4: Remove the drain bolt with a flat head screw driver. (This step is optional, but it will helps to reduce the mess while removing the filter)
Drain Plug (This is the plug we need to use if the water in fuel lamp glows)
Step 5: Now use a 36 mm socket to remove the filter housing cap
Old Filter and Filter Housing Cap
The Filter Housing
Step 6: Replace the O Ring
Remove the old O ring by using a flat head screw driver
Then install the new one
Step 7: Install the new filter into the filter cap assembly
The filter fits only in one direction, so no need to worry about messing up[:)]
Step 8: Install the filter back into the assembly
Now install the drain bolt back and apply a little bit of diesel in the o ring before installing the filter cover assembly to make sure it seats properly while tightening.
Be gentle while tightening the filter assembly, it may break easily if you use too much force to tighten it. Just make sure the cap is closed properly like in this picture.
Do not forget to install the clamp back.
Step 9: Bleeding the Air
Many ASC and Local Garages do this process by simply turn the ignition on and off several times to build pressure in the fuel lines. But i don't think this is a proper method, because while doing this the air in the line is not bleeding out. It is just compressing the air by the diesel. As the beat's high pressure pump is very sensitive, this small mistake may affect the life of the pump drastically and i don't like to take that risk. So i use the following step to bleed the air in the fuel line..
Remove the fuel pipe connection from the filter to the high pressure pump.(Just press the button in the adapter and pull the adapter upwards to remove the adapter)
Fuel line removed
Now put the fuel line inside a bottle and turn the igniton on and off for 8-10 times.
While doing this you can hear the air escaping from the line like our water tap [:D]. After some on and off's, you can see the fuel flowing continuesly from the pipe without any air. This means that you are successfully bleed the air in the system.
Now, install the fuel line back by simply pressing it in (Make sure you hear a click sound while doing this).
Voila!! Task Completed! [clap]
mayankdixit
kanpur
Very good DIY. Neatly completed too. I appreciate and like your diesel saving trick with the bottle. Well done.
At what intervals do you change your diesel filter?
How difficult is it to procure spares for your car, considering the present GM scenario?
Thread Starter #22
Kollam
Thank you....[:D]
I change the diesel filter every 5k Kms..Because,as per the condition of the fuel available in our fuel stations, the filter may clog easily and a clogged filter kills the fuel pumps and injectors pretty soon. So its better to change it every 5K.
Right now, there is no issue with the availability of spare parts.
Every part is available and service centers are still functional. If any part is out of stock in the service center, we need to wait for 3/4 days.
deville_56
THINGS NEEDED
13 mm ring spanner
Diesel Filter
Drain pan
PROCEDURE
( This will gave more room to remove the filter) View attachment 269876
The filter housing.
View attachment 269887 View attachment 269888 Drain Plug (This is the plug we need to use if the water in fuel lamp glows)
View attachment 269892 Old Filter and Filter Housing Cap
View attachment 269893 The Filter Housing
View attachment 269894 Remove the old O ring by using a flat head screw driver
Fuel line removed
Could have posted a month back saving me from the gush of diesel onto my mouth lying under the car [lol]
Routine spares are readily available at dealer, but price going high marginally every time. Aftermarket parts are available easily like the filters and suspension parts from reputed brands like UFI, Purolator, etc.
deville_56
@Auto_Psycho Is there any way to procure the service manual? Or is it possible to activate the stock fog lamp wiring just by adding the combination switch with fog lamp function and the missing relay and fuse? I traced the whole wiring from fog lamp to fuse box to combination switch, but somehow it is not working with various combinations of extra 2 wires in the combination switch assembly.
Thread Starter #26
Kollam
DIY: How to replace Strut Mounts (With Bearing)?
Recently my Beat was making a 'Thud' sound when driving though potholes in the highways. As i replaced my lower ball joints,tie rod ends and stabilizer links earlier (at around 30K kms), i am pretty damn sure that the sound was not coming from those parts. The only thing i didn't replaced at that time was the mount bush. So i am sure that the culprit is the Strut Mount Bush. But for a confirmation, i checked it and found that my assumption was correct!
What is a Strut Mount?
Strut Mount a component that attaches the suspension strut to the vehicle.It insulates the tire noise & vibrations from the vehicle. Many (front) strut mounts also contain a bearing or bearing plate that serves as the steering pivot.A strut mount is like a sandwich. One side bolts to the vehicle, the other side to the strut. In the middle is a rubber-like insulating material. So as the vehicle moves and goes over bumps, the up & down impact pushes and pulls at the mount. The mount’s job is to cushion the impacts to reduce the jarring effect, noise and vibration that could transmit into the vehicle.On many front struts, the mount also includes a bearing that the strut attaches to. With one on each side of the vehicle, these bearings act as the steering pivots. The bearing is a critical component that affects steering movement smoothness and response.
Symptoms of a Bad Strut Mount
- Clunking noises
- Vibration
- Loose, stiff or noisy steering
- Tire alignment
- Tire wear
Okay, so that's enough talking; Lets jump into the DIY! [evil]
THINGS NEEDED:
Mount Bush Kit
1/2 inch Socket set and its handles (L & T) and extensions
T50 Torx
T40 Torx
Hex Bits set/Allen Key Set
Ring Spanners
Jack
Jack Stands
Thread Locker
Multipurpose Grease
Spring Compressors
WARNING: Before we get started, i need to mention that the coil spring compressor used in this diy is a very dangerous tool. Improper usage of these coil spring compressors may cause serious injury or death. If you don't know how to use a coil spring compressor properly, do not try to do this diy. I am not encouraging newbies to use this dangerous tool. I am just explaining the procedures of how to replace a Strut Mount to prove that these jobs can also be done at home by ourselves [:D]. If you are planing to use this coil spring compressor, use it carefully AT YOUR OWN RISK. I am not responsible for any damage that happens due to the mishandling of this tool. If you don't know how to safely use these compressors, you can take the struts to your FNG and replace the mount bushes from there.
PROCEDURE:
Step 1: Jack up the front of the car and support it on Jack Stands
While jacking up, make sure the floor is strong enough to hold the weight of the car. ( Do not try to jack up the car in a sandy floor)
Step 2: Remove the Wheels
Step 3: Remove the a Caliper mounting bracket bolts and remove the whole caliper assembly
Before removing the bracket bolts,remove the brake hose from its guide by simply pulling it outwards
Remove these two bracket bolts
Bolts removed
Keep the caliper assembly aside without giving stress to the brake hose.
Step 4:Remove the stabilizer link
Use an appropriate hex bit/allen key to hold the ball joint and use a ring spanner to remove the nut
Stabilizer link removed!
Step 5: Remove the bolts holding the strut and knuckle and separate it
Remove the two bolts holding the strut and knuckle
Step 6: Remove Wiper and its complete panel assembly
I am sorry that i forget to take the picture of this process.[frustration]The process is quite simple, just remove some nuts,clips and wiper motor wiring harness and you can easily remove wiper and its related panels. By removing this, we get a lot of room to use the tools.
Step 7: Remove the nut holding the strut assembly and remove the complete strut assembly
Use T50 torx bit to hold the strut and use ring spanner to remove the bolt
Bolt removed!
Remove the strut assembly
After Strut removed!
Step 8: Compress the Spring
Strut Assembly!
Insert the jaws of the spring compressor into the springs and tighten the compressor.
Keep in mind that if the jaws of the compressor slips while tightening (Check the above pic), the spring may shoot at you at an EXTREEEME force and that is enough to kill you. So be very careful while doing this. While tightening the compressor tighten both compressors evenly. If you try to compress from one side completely the spring may bend to one side and slip from the jaws of the compressor and thus creating a dangerous scenario. So compress it evenly.
Spring compressed!
Step 9:Replace the mount bush
Remove the nut holding the strut mount. (Do not try to remove the nut without compressing the spring)
Nut removed
Old damaged strut mount
New One!
Old vs New
Check out the height of the bushing material,this gap is creating the 'thud' sound while hitting potholes.
Clean the old grease and dirt and apply fresh new grease
Do not forget to apply grease to the bearing too..
Install the strut mount back and tighten the nut.
Loosen the spring compressor carefully and evenly to avoid casuality.
Step 10: Install the strut back
New strut mount kit comes with new mount plate also
New mount plate.
Tighten the nut.
Step 11: Align the knuckle properly into the strut and tighten the bolts
Before Installing the bolts,clean the threads using a metal wire brush.
Apply a little bit of thread locker to the threads of the bolts to prevent it from loosening up due to vibration
Tighten the bolts.
Step 12: Install the Stabilizer Link
Insert the stabilizer link into the strut and tighten the nut.
Step 13: Install the Wheels
Step 14: Do the same steps to other side also
While replacing strut mounts, always replace them in pairs.
Kudos Job Completed! No more annoying 'Thud Thud' [cheers]
Thread Starter #27
Kollam
@deville_56 No, the service manual is not available anywhere. I searched a lot for getting one. But can't find one! [frustration]That's the motivation for starting up this thread! [:D]
I am not sure about activating the fog lamp wiring,because mine is LT variant and it already has fog lamp.So i didn't get a chance to experiment in those areas.
If there is a wiring harness for fog lamps, there is a good chance that it can be activated.[:)]
deville_56
- Clunking noises
- Vibration
- Tire alignment
- Tire wear
THINGS NEEDED:
Mount Bush Kit
T50 Torx
T40 Torx
Ring Spanners
Jack
Jack Stands
Thread Locker
Multipurpose Grease
Spring Compressors
PROCEDURE:
Bolts removed
Bolt removed!
Strut Assembly!
Spring compressed!
Nut removed
New One!
Old vs New
View attachment 272084 View attachment 272085
New mount plate.
Tighten the nut.
Tighten the bolts.
Making life easier for other poor souls. Likes the statutory warning, indeed most of them wouldn't take it seriously until learning the hard way. Another example is the chain lubing accidents.
@deville_56 No, the service manual is not available anywhere. I searched a lot for getting one. But can't find one! That's the motivation for starting up this thread!
Dug through the international Chevy forum. Got a lead that it would work with the addition of missing elements and the switch, but I doubt something is missing. Combination switch costs around 1k, so wanted to clarify before getting one.
Also got the sad fact that Chevy never released the repair manual for Beat, but announced pre-publication at $300.00, which never materialized. Such an irresponsible brand. Maybe there would be a dealer version with separate revision add-ons. Last hope is getting hold of that.
Thread Starter #29
Kollam
Before purchasing the combination switch, why dont you try to add a relay and short the wiring of combination switches for the fog lamp and check if the wiring harness for fog lamps is getting power? [think]
mayankdixit
kanpur
- Clunking noises
- Vibration
- Tire alignment
- Tire wear
THINGS NEEDED:
Mount Bush Kit
T50 Torx
T40 Torx
Ring Spanners
Jack
Jack Stands
Thread Locker
Multipurpose Grease
Spring Compressors
PROCEDURE:
Bolts removed
Bolt removed!
Strut Assembly!
Spring compressed!
Nut removed
New One!
Old vs New
New mount plate.
Tighten the nut.
Tighten the bolts.
Very well done.And very well explained too. Very good DIY. Its a back breaking exercise, and takes a lot of patience+muscle power. Its highly risky too.
I know it all because I too changed all 4 struts of my Swift ,and one of the front strut of my petrol Ritz at home in 2016 , all by myself. I purchased them from the parts catalogue no. and went about doing it. And I would not like to repeat that exercise ever. I did it over a period of 4-5 days.I used to get too tired after all that.I am happy You took all the safety precautions.Still there is a fear that spring compressor tool may slip,or the car may fall down.
How do you take pics of each step,when you are so keenly working on the struts and all.Just curious.
