Triumph Tiger 1200 (2022) Revealed
Triumph Motorcycles decided to end the year on a stunning note as they have revealed the much-improved version of their biggest and meanest ADV – the Triumph Tiger 1200. The new 1200 range comes in a total of five variants namely GT, GT Pro, GT Explorer, Rally Pro and Rally Explorer. The new model gets a new fascia that is instantly recognisable, all thanks to a horizontal DRL that has replaced the brow-style LED DRLs. Coming to the powertrain, the Triumph Tiger 1200 range draws power from a new 1,160cc inline three-cylinder engine that now produces 150 hp of power at 9000rpm along with a peak torque of 130Nm at 7000rpm. That said, this is an increment of 9 hp and 8Nm compared to the previous model.
Not only this, but the new Tiger 1200 has also managed to save an impressive 25kg of weight, out of which 5.4kg of weight-saving only comes from the lighter frame and the bolt-on aluminum subframe. That said, the Tiger 1200 now tips the scales at 240kg for the GT and 265kg for the Rally Explorer. Triumph Motorcycles says that the uneven firing order on the new Tiger 1200 improves low-end tractability for off-roading without a compromise on the top-end grunt that is beneficial for highway touring.
The suspension set up on the Tiger 1200 comprises Showa semi-active suspension while the stopping power is thanks to Brembo Stylema calipers. The new 2022 Triumph Tiger 1200 range uses a 19/18-inch alloy wheel set up for the GT and 21/18-inch spoke wheel setup for the Rally versions. The seat height for the GTs range from 850mm to 870mm while that for the Rally Pro and Rally Explorer are from 875mm to 895mm. Now, one of the key highlights of the new 2022 Triumph Tiger 1200 is the new Blind Spot Radar system and Lane Change assist that has been developed with Continental. However, this is reserved just for the Explorer models.
Other noteworthy bits on the new Tiger 1200 include cornering traction control, ABS, hill hold control, quickshifter, heated grips, electronic cruise control, adaptive cornering lights, and also, six riding modes. The Explorer models come with additional heated seats as well. The cockpit is a new 7-inch TFT display that supports smartphone connectivity, navigation, and GoPro control as well.
The Explorer models come with a reasonably large 30-litre fuel tank against a standard 20-litre unit on the rest of the models. The new Tiger 1200 will be a direct rival to the likes of the BMW R 1250 GS in the high-end, full-fledged ADV segment. India launch of the new bike is expected to take place during the initial months of 2022.
Credit: ExpressDrives
2022 Triumph Tiger 1200 launched in India
The 2022 Triumph Tiger 1200 has been launched in India now, which is available in two variants and four trims. Prices of the all-new Tiger 1200 start at ₹ 19.19 lakh for the GT Pro, 20.69 lakh for the GT Explorer, 20.19 lakh for the Rally Pro and going up to ₹ 21.69 lakh for the top-spec Rally Explorer variant. All prices are ex-showroom, India. The new Triumph Tiger 1200 is the brand's flagship adventure motorcycle, and it goes up against the BMW R 1250 GS and the Ducati Multistrada V4. Bookings for the new Tiger 1200 began in December 2021 and deliveries are likely to begin early next month.
The Tiger 1200 gets a new 1,160 cc inline three-cylinder engine that belts out 147 bhp at 9,000 rpm and delivers 130 Nm of peak torque at 7,000 rpm. The new Triumph Tiger 1200 will arrive in two variants - GT and Rally. As the names suggest, the Rally is the off-road biased variant, while the GT is meant more for riding on tarmac. Triumph will further offer the Triger 1200 in two trims on each variant.
The Tiger 1200 GT Pro and Rally Pro feature 20-litre fuel tanks with up to 400 km range, while the Rally Explorer and GT Explorer get larger 30-litre fuel tanks with up to 600 km range. The GT range also rides on 19-inch front and 18-inch rear alloy wheels with the model being more road-biased. The Rally range runs a 21-inch front and 18-inch rear set up with spoked wheels along with longer travel suspension. Compared to its predecessor, the new Tiger 1200 is about 25 kg lighter.
The new Tiger 1200 gets a host of electronic aids, full-LED lighting, a Bluetooth-enabled colour-TFT display, cornering ABS, cornering traction control, cruise control, blind-spot radar system, and Lane Change Assist feature along with adjustable seat height. Of course, there are a bunch of accessories to choose from as well.
