Transmission Oil For Maruti S-Cross Diesel
pithoragarh
Hi. I have this question. Please answer. Maruti S-Cross Diesel.
Can I use GL 4 75w90 transmission oil instead of (specified) 75w80 in my car?
Trivandrum , Sydney
The use of the higher viscosity will make shifting harder and will wear out the main shaft in the transmission, as it will not flow into the needle bearings.
"I receive many complaints from people about how hard it is to shift their manual transmissions after an oil change. In every case, going back to the originally recommended 75W-80 or 75W-90 oil fixes the problem. There are even some dealers who put 75W-90 in and have complaints.
A local Suzuki dealer has a problem with a transmission that they could not "solve". They were about to order a new one under warranty, but the service manager called me for advice. I sent him some 75W-80 as a sample and solved the problem, becoming their supplier.
Not only is the 75W-90 too thick, but in many cases has the old traditional additives, which hurt the brass or fiber synchronizers. The 75W-80 and 75W-85, (and some 75W-90) do not have that high amount of sulfur/phosphorous extreme pressure additive, depending more on magnesium sulfonate and others."
Source- Richard Widman, Automobile Specialist
pithoragarh
came across Mannol 75w80 but thats almost Rs 1500 per litre.Bodmoo offering maruti ecstar 75w80 at Rs 4010 for a 3 ltr can.as i see recommended grade of 75w80 means only synthetic oils which are the costliest.
