Tata Nexon EV Max: The Long-Range Nexon EV
Long-range Tata Nexon EV to launch on April 20
Tata Motors is expected to launch the long-range Nexon EV on April 20, 2022. Featuring a larger 40kWh battery pack, it will effectively increase the car’s range to an estimated 400km on the official test cycle. The long-range Nexon EV is expected to be sold alongside the existing Nexon EV, giving buyers a choice in terms of range and price.
The biggest update on the long-range Nexon EV will be a larger 40kWh battery pack. It is a significant 30 percent increase over the existing model’s 30.2kWh. To accommodate the larger battery pack, Tata Motors will modify the Nexon EV’s floor plan, and the boot space is also likely to be sacrificed.
The larger battery pack, however, does result in a significantly higher range. The existing Nexon has an ARAI-claimed range of 312km, and the updated model is expected to have a range of over 400km on the official test cycle.
The long-range Nexon EV is also expected to get selectable regen modes, allowing drivers to adjust the intensity of regenerative braking, which, in turn, improves range. While the existing Nexon EV also gets variable regen, it is mild and non-adjustable. What can also be confirmed is that this variant will also get some additional features such as ventilated seats, cruise control, park mode, Electronic Stability Control (ESC) and more.
Long-range Tata Nexon EV to launch on May 11
Tata Motors will reportedly launch the new 2022 Nexon EV on May 11, 2022. The upgraded Nexon EV is said to offer a long range than the current model. Previously, the 2022 Nexon EV was scheduled to launch on April 20.
The Tata Nexon EV SUV will come with a larger battery pack that will help to increase its range, which is speculated to be 400km.
Notably, the current Nexon EV provides a range of 312km (ARAI) on a single charge. However, the real-world range of 200-220km is offered by Nexon EV. The new Tata Nexon EV is expected to offer a range of 400km. This roughly means that the real-world mileage that the users will get is around 300km.
The long-range Nexon EV is also expected to get selectable regen modes. This will enable drivers to adjust the intensity of the regenerative braking, which helps in further improving the range. While the existing Nexon EV already gets regen braking, it is mild and non-adjustable.
The 2022 Tata Nexon will get a price hike of around Rs 3 lakh to Rs 4 lakh over the current Nexon EV. This roughly means that the final price of the Nexon EV will be around Rs 18 lakh. However, the long-range variant of Nexon will be sold alongside the current generation of Nexon. In this way the company can provide more choices to customers to choose from as per price and range.
Tata Nexon EV Max debuts on 11th May (11:30 AM). Sharing the link to live webcast.
Tata Nexon EV MAX - Launch updates
Visually, the new long-range Tata Nexon EV Max will largely remain identical to the regular model, however, we do expect to see the addition of a 'Max' badge on the EV. The cabin too is largely expected to remain unchanged.
Expect the long-range Tata Nexon EV Max to be sold alongside the existing model, however, right now Tata has removed the prices of the current Nexon EV from its website so it remains to be seen which direction the company takes.
The new Tata Nexon EV Max. Company says it offers 30% bigger battery. The Tata Nexon EV Max comes with a bigger 40.5 kWh battery with a maximum ARAI certified range of 437 km.
Tata Nexon EV Max launched at Rs 17.74 lakh
Tata Motors has launched the long range version of the Nexon EV, dubbed as the Nexon EV Max. The new variant is priced from ₹ 17.74 lakh, going up to ₹ 19.24 lakh (ex-showroom,. Delhi). The model gets an upgraded 40.5 kWh battery pack with a claimed range of over 437 km. The model has also seen several upgrades on the feature front including changes to the cabin, centre console as well asore safety and tech onboard.
Equipped with a 40.5 kWh lithium-ion battery pack, the Nexon EV Max offers 33 per cent higher battery capacity, delivering an ARAI certified range of 437 km (under standard testing conditions). In comparison, the standard Nexon EV offers a range of 312 km on a single change. The Nexon EV Max produces 141 bhp and 250 Nm of peak torque. The company claims a 0-100 kmph sprint time to be under 9 seconds.
Tata has also improved the charging time on the Nexon EV Max that will be available with options of a 3.3 kW charger or a 7.2 kW AC fast charger. The 7.2 kW AC fast charger can be installed either at home or at work. This helps reduce the charging time to 6.5 hours. The Nexon EV MAX also supports a faster charging time of 0-80 per cent in just 56 mins from any 50 kW DC fast charger.
More Pictures
Electric sunroof
Wireless Charging
Elegant Cockpit Design
Boot space
Rear A/C Vent
Cooled Glove Box
Ventilated Leatherette Seats
Auto-dimming IRVM
i-TPMS (Indirect Tyre Pressure Monitoring System)
Air Purifier
Cruise Control
Jewelled Control Knob
ABS with EBD and BA
All four Disk Brakes
Auto Vehicle Hold (AVH)
Dual front Airbags
Electronic Parking Brake
ESP with i-VBAC
FireShot Capture 013 - Tata Nexon EV - India's Own Electric Compact SUV Powered by Ziptron_ - ...png
Performance MAX
FireShot Capture 014 - Tata Nexon EV - India's Own Electric Compact SUV Powered by Ziptron_ - ...png
FireShot Capture 015 - Tata Nexon EV - India's Own Electric Compact SUV Powered by Ziptron_ - ...png
Connectivity MAX
Fortfied Cabin
Harman Infotainment system
Hill Descent Control
Hill Hold Assist
IP67 rated Battery Pack and Motor
ISOFIX Anchorage
Panic Brake Alert
Bigger Battery Capacity
Multi-mode Regen​
Tata Nexon EV is all-set to embark on a challenging journey from Srinagar to Kanyakumari to create the record for the fastest K2K drive by an Electric Vehicle.
Starting 25th February, Tata Nexon EV will traverse through 4000 Kms in 4 days in a non-stop drive (stops to be made only for charging the car).
This exercise is aimed at showcasing the prowess of the Nexon EV in managing high speed and long distance travel and to highlight the availability of public charging network through the length and breadth of India.
Drive Safe.
