Here are some DIY done lately to the car.
1. Headlight park light bulb to LED strip
I'll posting more detailed pics on later on how this one is done, its quite easy and the needed tools are also simple.
Materials needed/used:
Super sticky double sided tape
Flexible LED strips 30cm
Headlight restorer
Spray Paint (any desired color) (high temp would be good too)
Silicon gasket maker High temp (any color will do)
Headlight restorer (I used this to clean the chrome parts of the headlight like the diffuser/reflector and the cover/plastic)
Polishing compound (optional, if you wish to polish your painted headlight parts)
Rubbing compound (this can be used if the restorer is not around, just apply minute amount so that it will not ruin the chrome or original paint, I used this to remove the excess paint that gotten to the wrong part, masking tape failed to adhere resulting to an opening.)
Tools needed/used:
Hair blower
Flat tip screw driver
Dull edge knife (short maybe 3 inch)
Buffing rug
Results:
I plan on opening this again, the chrome strip I attached suddenly lose it adherence after some minutes of letting the main beam on high
Comparison between the two, one been cleaned by the restorer one still filthy
Sometimes Mom's/Wife's beauty equipment is useful too
Headlight restorer
Tools needed/used:
Hair blower
Buffing rug
Results:
