MSRP - USD 9999
Model Number - IMZ-8.1037
Dimensions (LxWxH) mm/inches - 2580x1700x1100/101.6 x 66.9 x 43.3
Seat Height mm/inches - 813/32
Road Clearance mm/inches - 125/4.9
Dry Weight Kg/lbs - 320/705
Recommended max cruising speed km/h:mph - 105/65
Engine - OHV Air-cooled, four-stroke, flat twin cylinder
Bore & Stroke - 78 & 78 mm
Compression Ratio - 8.6:1
Displacement - 749 cc
Rated HP @ 5600 RPM - 40
Carburetion - Twin KEIHIN L 22 AA
Clutch - Dry double disk
Rated Torque @ 4600 RPM - 52 Nm / 38 ft-lbs
Alternator - 55amp, 770 watts
Starting - Electric & Kick-Start
Gearbox - 4 forward, 1 reverse, shaft drive
Fuel - 91 Octane Unleaded
Tank Capacity liters/gallons - 19/5.0
Front Brakes - BREMBO with full floating disk
Rear Brakes - Mechanical Drum
Sidecar Brakes - Mechanical Drum
Ignition - Electronic
Front Suspension (forks) - Leading Link
Rear Suspension - SACHS Hydraulic spring shock absorbers
Wheels Size - Front, rear, & sidecar 19"
Wheels Type - Painted steel, steel spokes, cast alum. hubs
Warranty - 2 years parts and labor, unlimited mileage
Fuel Mileage - 26-33 mpg/11-14 km/l*
Trunk Volume - 2.9 cubic ft/22 gallons
Options you may add - Second "tractor" seat or bench seat
Spare Wheel with Tire
Spare Wheel Luggage Rack
Tonneau Cover
Sidecar windscreen
Cylinder Crash Bar
Full Size Tool Kit
And more…
* may vary depending on load, speed, driving style and weather conditions
Tonneau Cover
Sidecar windscreen
Cylinder Crash Bar
Full Size Tool Kit
And more…
