Review: LED Headlight Conversion Bulbs For Cars & Bikes
And, can we only change High Beam bulbs to LED and leave with the existing low beam bulbs (Phillips Xtreme vision - Halogen bulb)?
(I feel the high beam lights need more/better light throw than low beam ones?)
I suggest you to convert the low beam to LEDs and let the high beam remain as Halogens.
Changing the high beam to LED will result in glare and improper output as compared to Halogen setup.
Low Beam bulb - changed from Halogen to LED
Finally, I have changed the low beam bulb (Projector) to LED. The brand name is Drive Maxx, and it comes with 120W Ultra white, 6000K. The company gives 24 month replacement warranty.
I know this is another Chinese make but the shop guy assuring 2 year replacement warranty hence agreed this brand.
Light visibility before LED installation:
Low Beam
High Beam​
After LED installation:
Low beam
High Beam​
Will have to check and take some pictures while driving on the road in the night time and see how the difference is. When I was coming home last evening after installation, I felt much difference in low beam brightness with the new LED installed. However, there are some yellowish vision when switch on to high beam.
Can you try and click a few images against any white or plain wall to know the lightning difference?!
I can also see 'yellow' output as you've highlighted which seems unusual unless it is the projector glass that is giving that yellow colour. Did you test the bulbs outside before fitting it?
It was pure white when checked at the shop. Will try to take some other shots on the road or some other convenient place where there are walls or compound.
The above pictures were taken at the shop immediately after the installation (believe both high and low beams were switched on at that occasion)!
See below couple of pictures taken last night after parking the car against home wall.
Low beam - shot taken from inside the car
Low & High beam - shot taken from inside the car
Shot taken from outside​
Now, will have to check how the vision looks like on the road in the night time.
