I could not find an answer to the questions I have wrt paid service of our cars. For the paid service we have been charged with some amount and in my case Rs1300+ for my beat. I have no other serious issues with my car except some ride comfort issues. During the visit to service center for my regular service 37K Kms, I have been forced to perform below checks by SA.
1. WA/WB
2. Engine tuning
3. Engine decorbonising
4. Door adjustments
5. Both break cleaning
I do not remember all other things which SA told me to perform on the car. All these things would have come to close 4K (excluding paid service charges) and it will come to 6k for a service which does not need oil change itself. I have clearly told him that I have no serious complaints with the car and do only the usual checks as part of paid service. On hearing this he was out of words and told me that they do only electrical checks and washing of the car. I do perform WA/WB at regular intervals from an outside shop as this is advisable to do every 5k kms.
I checked chevy website and they have clearly mentioned below checks need to be performed on 37K Kms service,
Periodic Service: 30 months/37,500 kms
Inspection:
Drive Belt (alternator, power steering and A/C compressor)
Engine Oil and Engine Oil Filter
Cooling System and Hose Connections
Engine Coolant
Fuel Filter
Fuel Line and Connections
Air Cleaner Element
PCV System
Exhaust Pipe & Mountings
Brake / Clutch Fluid
Front Brake Pads & Discs
Rear Brake Drum & Linings
Parking Brake
Brake Line & Connections (Including Booster)
Chassis & Underbody Bolts & Nuts Tight / Secure
Tire Condition, Inflation Pressure & Rotation
Steering Wheel & Linkage
Manual Transmission Fluid
Drive Shaft Boots
Safety Belts, Buckles & Anchorages
Lubricate Locks, Hinges & hood Latch
Pollen filter
Battery
Lamps & Bulbs
Wiper Blade
Total Cost*:
Rs. 1,320/-
Can you please clarify my concerns that, should I perform all items told by SA for 37K incase I do not have any issues with my car at all? How do I verify/cross check that all checks mentioned above has been performed on my car ? and I seriously doubt that all above checks has been done with the car. this happens everytime I go for servicing that SA forcing to take all checks even for 15K/20K service without oil/filter change. 5-6K towards normal service for a hatchback looks quite a lot.
Cheers
1. WA/WB
2. Engine tuning
4. Door adjustments
Inspection:
Engine Coolant
Fuel Filter
Air Cleaner Element
PCV System
Parking Brake
Drive Shaft Boots
Pollen filter
Battery
Lamps & Bulbs
Wiper Blade
Total Cost*:
Rs. 1,320/-
Cheers
