New Volvo EX30 Unveiled
Volvo wants half of its cars to be pure electric within the next 18 months – and a major part of that will be this new pint-sized SUV. It’s called EX30, priced from less than £34,000 and due to land in UK showrooms in the autumn.
The Volvo EX30 is the Swedish brand’s smallest SUV ever, and it draws heavily on technology developed by Volvo’s parent company, Chinese conglomerate Geely. The car uses Geely’s Sustainable Experience Architecture (SEA), a platform that also underpins the recently launched Smart #1.
Volvo’s offering is 4.23 metres long, making it the most compact EV offered by any of the recognised ‘premium’ brands. It’s almost 30cm shorter than Audi’s Q4 e-tron, for example, and nearly 25cm shorter than both Mercedes’s EQA and Lexus’s recently updated UX 300e. Its natural rival could well be the all-electric version of MINI’s forthcoming Countryman, although even that car is set for a growth spurt that will take it beyond the EX30’s size.
Using the bespoke SEA platform, which has been designed from the ground up for all-electric vehicles, means that the Volvo’s wheelbase is 2,650mm – only five centimetres shorter than that of the considerably larger (but combustion-based) XC40. The styling is unmistakably Volvo, with a further evolution of the firm’s trademark ‘Thor’s hammer’ lighting signature and an upright stance, complete with very short overhangs and a near-vertical rear glass area, that gives the EX30 a chunky look. Volvo has also confirmed that an EX30 Cross Country will arrive in 2024, sporting a more rugged look, bespoke alloy wheels and a raised ride height.
There are three core technical configurations of EX30. The version called Single Motor has a drive unit on the rear axle, producing 268bhp and 343Nm, and it’s available in two guises. The first has a 51kWh (49kWh net) LFP-chemistry battery, enough for up to 212 miles of range and 0-62mph time of 5.7 seconds. It can charge at up to 150kW, potentially taking the battery from 10 to 80 per cent of its capacity in 26 minutes.
There’s also an Extended Range model with the same motor but a larger 69kWh (64kWh usable) battery that uses more energy-dense NMC chemistry. It manages 0-62mph in 5.3 seconds, and an identical top speed of 112mph, but can travel up to 298 miles between recharges. It’s also quicker when hooked up, with a maximum DC rate of 175kW – so despite the larger battery pack, the 10-80 per cent time is roughly the same, at between 26 and 28 minutes.
The range-topper is called Twin Motor Performance. It has the same battery and charging speed as the Extended Range, but trades some range for the extra punch of an additional motor on the front axle. The total output is a whopping 422bhp and 543Nm, and this EX30 can hit 62mph in just 3.6 seconds. Its WLTP range falls to 286 miles, though.
Inside, the Volvo EX30’s fascia is dominated by a large portrait-layout infotainment system which sits above a central glovebox that’s designed to be easily accessible by both driver and front passenger. Volvo’s designers have been able to drop conventional door-mounted speakers and fit larger door pockets, thanks to a sound bar that, in effect, becomes the entire top edge across the dashboard.
Autoexpress
The Volvo EX30 sounds absolutely impressive! It's fascinating to see how Volvo continues to push the boundaries of automotive technology and design. The sleek and elegant exterior, coupled with the advanced features and innovations, make it a standout in the compact SUV segment. I was particularly intrigued by the mention of the state-of-the-art safety systems and the hybrid powertrain options. It's great to see a car manufacturer prioritizing both performance and sustainability. I can only imagine how thrilling it would be to get behind the wheel of the EX30 and experience its power and efficiency firsthand.
Volvo has confirmed that EX30 will be introduced in India by end-2025. The company is also assessing the feasibility of assembling it locally. (Source: Link)
