Re: WagonR CNG ICE
If you feel that you need more bass, and are unsatisfied with the bass output of the Kicker, you should go in for 6x9 coaxials on a parcel tray. Even 6.5" round coaxials won't perform well and give much bass than a 6x9 oval mounted on an MDF tray. If you buy premium 6x9 coaxials, you can altogether eliminate the need of a subwoofer/basstube (as they can produce bass equivalent to an 8" sub).
So, you have 2 ways to go through this problem IMO:
1. GET 6X9 COAXIALS ON AN MDF TRAY:
This method is a tried and tested method. The coaxials have a more cone surface and would push more air, resulting in better bass. Don't get fooled by the max. power ratings though, it is the RMS rating which is more useful in comparing the brands. Don't go for Sony. JBL, Pioneer, GZ, Blaupunkt, Hertz, Infinity and Polk are some good brands in your budget of 5k. JBL GTO series is a very reknowned speaker series (especially the 949) and would cost under 5k. If you are dead serious about bass, there is nothing better than Pioneer. You should audition all these speakers before deciding to avoid troubles in future. Personally, I would advice Pioneer 6X9 speakers on an MDF tray. MDF tray would cost additional ~1k.
And I didn't understand your logic of "nothing close to the CNG tank". CNG tank is very sturdy and would literally have negligible effect due to the thumping of the speakers.
2. GET AN UNDERSEAT SUBWOOFER:
An underseat subwoofer is a very uncommon method of getting some decent bass in the cabin. The usual sizes are 8" though you may find some 10" also. I have only heard Xenos 8" underseat subwoofer and was not satisfied with the output. If produces limited bass, best comparable to good 6x9 speakers and the price tag is often hefty as most of them have an inbuilt amplifier. The entire thing would cost around 10k.
According to me, option 1 is the better choice.
First, I would advice you to get only the coaxials fitted on the tray. If you still need more bass or quality out of your music, then get an amplifier. A 4 channel amplifier would be preferred as powering only the rear speakers would make the soundstage rear-heavy. Powering only the front would be no problem though (the front speakers would be more pronounced than the rear). In 5k, you can look for JBL GXA644SI. Other brands are Pioneer, GZ, Kenwood and the like. Don't go in for a V12 amplifier or Sony. Compare the RMS ratings before buying and ensure that the RMS of the amplifier is more than the RMS of the speakers (or equal).
Creating a rough idea for the price
First stage (~5k)
1. JBL/Pioneer 6x9 : Rs. ~4k (for w/o bill and warranty, ~3k)
2. Wiring and Labour : Rs. ~1k (or less)
3. MDF Tray : Rs. ~1k
For next stage (~6.5/7k)
1. JBL/Pioneer 4 Channel Amplifier : Rs. 5k (w/ bill and warranty. 3.5k w/o bill and warranty IMO)
2. Amp Wiring Kit : Rs. ~2k (depending on the brand. Starts from mere 500 bucks to hefty 5k and more)
3. Labour : Rs. ~1k (or less)
Note that the amp can be mounted under the front seat.
You can waive off the labour charges by negotiating hard.
Nikunj
