Maruti Suzuki Omni: Technical Queries & Solutions
tirupur
Hi every one. I am new for TAI. one fine day i am in google i saw Tai and came inside .after get in i seen post and thread of (varun560061,rao66,ss80,rayal) especially i like varun's my modified 800 thread. i read full post night fully that much i like his modification job and diy.
And My self viswanathan (viswa). i own tvs apache rtr. i am doing business (textile), now in tirupur. birth place salem. i love driving.
And now coming to the point i plan to buy maruti omni for both business and own purpose, so i choose omni. when i think to buy a car in my mind first came alto 800 or santro. my wife too like that only but my mum and dad told for business we want omni only and for easy ingress its only omni. so i to finally decided to get omni.
But i have some doubts
are omni engine and 800 engine same?
same engine means why can't ac fit in omni?
does omni gives same mileage that 800 give?
for servicing omni is easy DIY or I have to go to MASS?
does omni comes with brake booster?[confused]
tirupur
Re: Buying a Maruti Omni: General Technical Queries
[:)] thanks for quick reply akash. but my doubt is ac can possible in omni
See, the AC vents can be roof mounted for rear passengers like the one's that come in Ertiga. In the front you will get 2 vents just like other vehicles.
The main concern is where to place the AC machinery in OMNI since the engine is located beneath the driver's seat. At the best you can make a place for AC machinery below the front passenger seat.
tirupur
so aftermarket fan fitting is only way for this ...and any other aftermarket cooling mechanism have with out connect to engine just by battery source it will work like that?
Well not that I can think of as of now. Why don't you give a look on the Maruti Eeco? It is also a good vehicle for personal/ commercial purpose and sits 7 passengers comfortably and comes with an OEM AC too.
tirupur
ya eeco is also correct choice for both business and personal but its financial problems to get eeco[cry]. omni second hand well maintain comes around 1.5 to 2 thats why i stick in omni [lol]
Suppose o fit fan front one and in back two fan means is it affect battery that remains battery will withstand that. any extra battery arrangement need? or alternator upgrade need?
tirupur
today i seen omni badge in rear boot as (omni) in some van and (omni E)in some van, is it any difference in this omni/omni E?
Maruti Omni after 10-15 min jerking when it jerks something tick tick voice comes(ticking sound accompanying the jerking) and when it turns off i need to turn off headlight then start or else van doesn't start whenever I give race it jerks and temprature is near 60% again if you give it time too cool down completely or start tomorrow it will work for another 10-15 min and again issue starts
(Maruti van old model )
Great Bentley United Kingdom
difficult to understand what you mean. Can you post a video clip ? It sounds like it may be an ignition timing issue.
Is the distributor loose ? , can you turn it by hand ?
Check the distributor cap for cracks or signs of tracking.
Change the plugs.
Check/change the spark plug leads.
Check oil and coolant levels.
Check for loose battery and earth connections.
Drain the fuel system and tank, use fresh quality petrol.
Regards Neil
Just realised you posted earlier about replacing the headlight relay. Check all the wiring and fuses near the relay. You may have caused a loose connection in another circuit that is affecting the engine.
Change the plugs.
Regards Neil
The jerking issue existed before replacing the relay.
(Change the plugs.
Drain the fuel system and tank, use fresh quality petrol.)
Checked all above mentioned things
Will have a look on distributor cap for cracks or any signs damages
The problem seems to occur only after I've been driving for 10-15 minutes. If it were a grounding or wiring issue, it should start as soon as I start the car. However, my car jerks after 10-15 minutes.
And when it starts jerking, it only stops if we give the car a rest, like a 2-3 hour gap or run the car the next day. Again, we get about 15 minutes of smooth operation before it starts jerking again,
And in those 15 min temprature goes to 60-70%
Hi, remove the fuel filler cap, plug the hole with a loose fitting piece of cloth, do not make an air tight seal just keep the dust out. Drive the car and see if the problem goes. It may be that the fuel tank air vent is blocked. When this happens the pump cannot pull enough fuel from the tank and the engine runs lean starved of fuel. A vacuum starts to build up in the tank if the vent is blocked.
Regards Neil
I had oil leak in my maruti Omni gen 1 so somone suggested to change the delco packing (delco i think they mean distributor)
So I bought the packing but we're should I install it.
If removing delco i think we will see o ring and the shaft were that packing will go
Attaching pics of packing and delco area
