Maruti Alto K10 VXi Power Window Childlock Query
Jammu
Hello all forum members!!
I am owning a maruti alto k10 vxi and as we all know that this car has only front power windows as oem. But i saw a very bad feature in its power window system.
Note: friends you all know that the child lock button on a power window is used to cut the supply to the three power window switches which are at the co-driver side and the rear doors.
As in case of maruti alto k10 vxi, when we enable the "child lock button" of the power window by pressing it, then the power window switch on the co-driver side door panel stops working--which is correct and ok ,
but problem is with the driver side door panel and it is like that the power window switch on the driver side door panel to control the co-driver's window also stops working ???
Tell me why is this happening??? And is there any diy job or technique to change its circuit to make this switch work even after the child lock is on??
Please provide a good solution for this to me .thank you all in advance
Regards!
Saalik
cochin
Did you checked it with other Alto Vxi cars? It will not be the same i guess. Either it will be problem with a bad wiring or part problem. Contact ASS immediately. If your car is new, you can expect a replacement or repair.
Jammu
this is with all Maruti Alto k10 vxi models , Actually this is by default but I want to make alteration in thepower window circuit to make it work independepntly..Guess there will be someone with a a correct solution for my query.
Kochi
I checked the same in my friends vxi. This issue is a default feature of K10. You better to try some diys to remove the lock from the master switch.
