Re: Maruti 800: Technical Issues and Solutions
If there is no oil why not fill the oil after getting the leak taken care of.
The mechanic must have quoted parts+labour might be including the gearbox oil.
Find the cause of the leakage.Get that issue addressed first.Try changing the clutch cable as well.See if the pedal shows improvement immediately after that.
If not then only go for a clutch kit replacement.
Also It would be a good idea to start a new thread and post all your car problems there.Makes it easier for other members to access your posts and you will get more help as well.Just name the threads appropriately and help will be on the way.
